How many positive integers x satisfy this logarithmic inequality?
The discussion focuses on solving the logarithmic inequality log_{x/8}(x^2/4) < 7 + log_2(8/x) for positive integers x. The solution involves transforming the inequality into a quadratic form y^2 - 11y + 28 < 0, where y = log_2 x. The critical points are identified as y = 4 and y = 7, leading to the conclusion that the valid range for y is between these points, thus determining the positive integer solutions for x.
  • Understanding of logarithmic functions, specifically log_2 and change of base formula.
  • Familiarity with solving quadratic inequalities.
  • Basic algebraic manipulation skills.
  • Knowledge of the properties of inequalities.
  • Study the properties of logarithmic functions, focusing on log_2 and its applications.
  • Learn how to solve quadratic inequalities, including factoring and testing intervals.
  • Explore the change of base formula for logarithms in depth.
  • Practice solving various logarithmic inequalities to solidify understanding.
Mathematics students, educators, and anyone interested in mastering logarithmic inequalities and their applications in problem-solving.
Mr X
How many positive integers x satisfy ##\log_{\frac x 8} (\frac{x^2} 4) < 7 + \log_2(\frac 8 x)##
Basic logarithamic rules
The whole solution is a bit long, which I'll attach but the part I'm stuck at is, assuming everything else above it is correct, is
4 < (log x - 3)(8-log x)
Note ; inequalities aren't technically taught yet in the course, so please try to make the solution not go too deep into that. If that isn't possible there's a high chance I've gone wrong before that step, hence I've uploaded the entire solution.
Did you try plugging in ##x = 1, 2, 3 \dots## and see what happens?
Mr X said:
Homework Statement: How many positive integers x satisfy ##\log_{\frac x 8} (\frac{x^2} 4) < 7 + \log_2(\frac 8 x)##
Relevant Equations: Basic logarithamic rules
Assuming your logs are to base 2 then this is one of the possible solutions. It is convenient to use logs to base 2; then the left hand side is <br /> \log_{x/8}(x^2/4) = 2\frac{ \log_2(x/4)}{\log_2(x/8)} = \frac{2 (\log_2 x - 1)}{\log_2 x - 3} and the right hand side is 7 + \log_2(8/x) = 10 - \log_2 x so that if y = \log_2 x then <br /> \frac{2(y-1)}{y-3} &lt; 10 - y.
To solve this, we must multiply both sides by y - 3. But this only preserves the inequality if y - 3 &gt; 0, and in that case <br /> y^2 - 11y + 28 &lt; 0 which is as far as you got, but you then did not factorise this as <br /> (y - 4)(y - 7) &lt; 0.
Alternatively, if y &lt; 3 then we must reverse the inequality when multiplying both sides by y - 3, which leads to (y - 4)(y - 7) &gt; 0.
sorry I didn't reply after, but got it, thankyou.
19K
  • · Replies 30 ·
  • · Replies 67 ·
16K
  • · Replies 71 ·
13K
