The weight of one US gallon of water is 8.33 pounds, making 90 gallons weigh approximately 749.7 pounds. The conversion from gallons to pounds depends on the substance's density, as there is no direct weight-to-volume conversion. For a 2x4's load-bearing capacity, factors such as wood type, orientation, and flaws significantly influence its strength. Construction-grade pine is commonly referenced, but the actual load can vary widely based on specific conditions. Calculating the strength of wood requires careful consideration of its properties and potential safety margins.
