How many state changes per second could optical computing do
31 replies · 4K views · last reply
IsItSo
Using Optical Computing, what is the max amount of state changes that 1 transistor could theoretically have within 1 second? I once read that an electrical transistor could achieve 100 billion state changes per second, but I'm wondering what the number is for light, *and what it could theoretically be without each state change requiring any stalling before it can do the next.
20 GHz ?... As I mentioned in my opening post, I've read about a 100 GHz electrical transistor, optical transistors (as some sources suggest) should at least be about twice as fast i.e. 200 GHz. (200 billion state changes per second)
One incredibly major problem...
400 million hydrogen atoms fit in an inch
63360 inches in a mile
25 thousand miles around Earth
times 7
= 4,435,200,000,000,000,000 atoms that light passes each second !
Light at least at least at least can therefore give us 4 quadrillion state changes per second (assuming each photon is right behind the other ready to do the next state).
And just think about how much space is in an atom, that's like 2,000 times the number I just gave us above !
times 7
I don't see the relevance of that to your original Q ?
photons are not like little bullets firing out of a gun
I am not sure the question can be answered.
The switching speed of a transistor will -obviously- depend on the type of transistor. There is no way you could predict the speed of a transistor capable of switching signals at optical frequencies by extrapolating the speed of normal electrical transistors; the technologies will be entirely different.
If the operational principle of the transistor was based on first converting the optical signal to an electrical current and then back again it would be much slower than an all-electrical transistor.
Also, there are electrical circuits (simple flip-flops based on superconducting electronics) that can operate at hundreds of GHz
mfb said:
Google searches suggest ~10-20 GHz for practical applications, but with theoretical speeds above 500 GHz (example).
Can't get the link to work. Do I need a subscription ?
Photons do not even have a well-defined position. Your calculation has no relevance to optical computing.
No subscription, but the link doesn't seem to work. I went there via google -> some captcha -> that PDF, apparently the direct link doesn't work, I'm not sure if the captcha link help. If not, search for "Photonic temporal integrator for all-optical computing site:osapublishing.org".
There are very fast transistors, but you need more than a very fast transistor to make a useful circuit.
So, the transistor described here
http://science.sciencemag.org/content/early/2013/07/03/science.1238169.full
seems to be based on atomic states of cesium-133, | g 〉 = | 6S1/2,F = 3,mF = 3 〉, | d 〉 = | 6P3/2,4,4 〉, | s 〉 = | 6S1/2,4,4 〉, | e 〉 = | 6P3/2,5,5 〉
The paper doesn't really say, but I suppose the switching frequency must be slow compared to all of the transition frequencies involved here.
NIST atomic spectra database gives the 6S1/2 - 6P3/2 transition as 852.11 nm, which would be a frequency of 3.5182*10^14 Hz. On the other hand, the hyperfine transition of cs-133 is 9.192631770*10^9 Hz, which is much, much slower. I suspect you will have problems bleeding of the gate photons and the main path if you operate near this frequency.
Because if they travel that far each second past that many atoms, while possibly doing as you said some "teleporting" i.e. doesn't take 4 Quadrillion moves, then if we send lots of photons to our target some will teleport at spots where the other didn't so you end up with 4 or more quadrillion.
Nevertheless, in our current optical computing I don't see why we haven't yet got such happening i.e. 4 quadrillion states per second. Maybe they didn't plan for it? They should be able to go a lot higher.
Photons don't teleport. You can transfer the quantum state of one photon to another photon, which is called teleporting, but that needs a classical information transfer and the whole process is slower than the speed of light.
Photons do not have a position - do you understand that part? Your whole speculation is based on an incorrect assumption.
So you're saying I should ignore the amount of atoms a photon passes in 1 second, and focus on what the latest foreseeable optical computing speed of states per second it is able to achieve? But then we truly won't theoretically know a definite number like I explained above...
So 200 billion state changes will probably be possible, but possibly not any higher in the future? (consider this number [200 billion], and look at how many atoms a photon passes each second - 4 quadrillion (+atomic-space), that's a STRANGE difference)
you are throwing out these crazy numbers and making wild assumptions without any backing references
you need to stop that please
No, I say that number doesn't exist. It's like asking how many atoms an invisible unicorn is made of.
How it is like asking how many atoms --- an invisible unicorn is made of, when I said the "invisible" photon is passing the (yes also fuzzy) 4 quadrillion (calculation above) atoms each second?
Back in post #11 of this thread we said "Photons don't have a position". How does it make any sense to talk about something that has no position passing anything else?
Because we can put a antenna at one place and another at the finish, and it has been calculated that photons reach (only) that far in 1 second, while if you're not in the way of the laser beam you're safe. This means it went a distance and a skinny-width way. The mere fact that it gives you more than 1 state change per second means something.
An antenna does not emit single photons. A laser beam is not made out of individual photons either - it is a coherent superposition of photons, which is a completely different thing. You cannot even count the photons in a laser beam.
Yes ok antennas emit many in all ways, and continuously. Lasers shoot many out. My last reply still stands...
Not necessarily.
No they do not.
If you want to learn: great!
If you want to ignore what everyone is trying to tell you, and rephrase your questions based on wrong assumptions over and over again: I don't think that is helpful. As long as you don't stop that approach, you won't make progress.
Let me deeply go through this. The element emits photons from all sides. Keeps doing so. And can focus them.
Doesn't my point stand that they will get to a certain distance in 1 second, and only come out of the long laser hole, and gives us more than 1 state change per second?
I realize we only can currently implement so many state changes (200 Billion optically?), But with the above (and the amount of atoms they pass) I can't see how it doesn't hold ground that they could give us 4 quadrillion state changes.
What if the optical transistors were atoms, so that when the photon leaves (and travels on that far distance) the next can come on in and quickly change the state?
no, they emit electromagnetic radiation ... as I said and others have also tried to tell you
Photons are NOT like little bullets shooting out of a gun
No, see my and others' previous comments
you are still coming from false assumptions
please reread mfb's last comment ...
you really have to stop with the bad ideas, information and assumptions, else you are never going to progress in your understanding of physicsDave
So what's the number for now then, 200-500 Billion per second for optical computing?
500 GHz (500 billion/s) seem possible according to the article I found, but tens of GHz look more realistic for actual computers. Computing happens at the speed of the slowest part (with some exceptions).
If you really push it and have super-incredible nanotechnology and can build with atoms could it reach 1,000 with instant-transistors/etc?
Also, is there any way we can figure this out without testing it?
That's the point of research: figure out what is possible and what is not. While theoretical models (those have to be developed as well) can often give a good prediction, we don't know before we test it.
Try re-reading post #20 and ask yourself if you have taken it on board.
It seems to me that you haven't.
Well...what about this:
New invention:
If we accelerate up an atom so it travels about 1 mile per second, and film it, we could see it slowly move by each atom! How many atoms does it pass in each mile? Each inch is 400 million hydrogen atoms. That ends up as way more than 500 billion.
New invention:
But atoms are not photons. Where is this going - apart from an attempt to justify your original ideas round by the back door. Better to start at the beginning, I think. This stuff has all been thought out by much cleverer people than you and I.
