How much heat is needed for converting 7 kg of ice to steam?
  • Thread starter Thread starter DrMcDreamy
    Heat
To convert 7 kg of ice at 0°C to steam at 100°C, a total heat of 5,036.5 kcal is required. This calculation involves three stages: heating the ice to 0°C, melting the ice to water, and vaporizing the water to steam. The specific heat of water is 1,000 cal/kg·°C, the heat of fusion is 79,500 cal/kg, and the heat of vaporization is 540,000 cal/kg. The total heat is calculated by summing the heat required for each stage: 700,000 cal for heating, 556,500 cal for fusion, and 3,780,000 cal for vaporization.
  • Understanding of thermodynamics principles
  • Knowledge of specific heat capacity
  • Familiarity with latent heat concepts
  • Ability to perform unit conversions between calories and kilocalories
  • Study the concept of specific heat and its applications in thermodynamics
  • Learn about latent heat of fusion and vaporization in detail
  • Explore the calculations involved in phase changes of substances
  • Investigate the differences between calories and kilocalories in thermal energy calculations
Students in physics or chemistry, educators teaching thermodynamics, and anyone interested in understanding heat transfer during phase changes of water.
DrMcDreamy
7 kg of ice at 0◦C is converted to steam at 100◦C. How much heat is needed? The heat of fusion for water is 79500 cal/kg, its heat of vaporization is 5.4 × 105 cal/kg, and its specific heat is 1000 cal/kg ·◦C. Answer in units of kcal.
What is the formula that I am supposed to use?
Q=mc\DeltaT ?
You *also* need to use
Q = mL,
where m is the mass and L is the heat of fusion/vaporisation.R.
you go from solid to liquid to gas, so you have to calculate the heat for each stage than add up the total of each stage. I think, also, for the vaporization you would use Q =ml where L = latent heat of vaporization.. and Q=ml again for latent heat of fusion/melting
I think that's how you do it...
You should end up with 3 separate values for Q which you will have to add up.
So:
Q=mc\DeltaT
Q=(7kg)(1000 cal/kg C)(100 C)
Q= 700,000 cal
heat of fusion:
Q=mL
Q=(7kg)(79500 cal/kg)
Q= 556,500 cal
heat of vaporization:
Q=mL
Q=(7kg)(5.4x105 cal/kg)
Q=3,780,000 cal
\sumQ= 700,000 + 556,500 + 3,780,000
\sumQ=5,036,500 cal = 5036.5kcal
Is that how?!
Indeed :)
Thank you!
  • · Replies 17 ·
