How much time does an object use to travel.
4 replies · 1K views · last reply
Nerikk
How much time does the object use to travel 12m down a plane. The object has a constant acceleration of 1m/s2 and the starting velocity is 5m/s.
S=V(starting velocity)*t+1/2*a*t2
Here I struggle with changing the formula. I could just leave both t's on the left side and then use square root. But I have a slight feeling that this is not right.
Very close - for that to work, the LHS needs to be a complete square.
Hint: quadratic equation
Aside:
I'm intrigued by the wording. Is time the sort of thing that gets used up by objects ... you know, like a car uses petrol?
Probably the question wants to know how much time is taken or occupied by an activity.
Yea, it's quite hard to word yourself correctly in another language. Especially in math. But I will check out quadratic equation! Thank you!
Oh it was a translation?! Well done - I couldn't tell. I wondered if maybe you just had a new-age physics teacher ;)
Since English is a second language ... I'll say a bit more.
The equation you are trying to solve can be put in form: ##At^2+Bt+C=0## - do so: A, B, and C, may be made of several variables.
You should recognize that as the equation for the roots of a parabola... you should know an equation to solve that. $$t\in \frac{-B\pm\sqrt{B^2-4AC}}{2A}$$
I think I need some more help on that one. First of all how do I achieve 0 on the right side of the equation. Second how do I determine the variables?
And thank you for all your help! It seems like I lack some fundamentals in physics, heh...
