How much work, speed and resistive force
11 replies · 3K views
Haveagoodday
A crane is slowly lifting a large box of mass 2 kg by means of a thick (but
massless) rope, from the ground to a height of 10.0 m.
a) How much work does the crane do on the box? How much work does
gravity do on the box?
b) The rope suddenly breaks and the box falls to the ground. What is its
speed as it reaches the ground?
c) Sofar, we have assumed that there is no friction of any kind. Now consider
the case when there is a resistive (air drag) force on the box as it drops down
from an initial height of 10,0 m. The resistive force is modeled by
with a = 0,2kg/m. What is the terminal speed vT of the box? Using Newton’s
second law, write down the differential equation for v(t).
d) The solution to this differential equation is of the form:
where tanh is the hyperbolic tangent function (look it up), and C is some
integration constant. If t = 0 is the time when the rope breaks, what should
C be? By direct integration, find x(t); the distance fallen as a function of
time. You will need that
where cosh is the hyperbolic cosine function (look it up). Find by insertion,
whether 1.67 s, 6.71 s or 7.16 s is (approximately) the time it takes do drop
to the ground.
a) W=196 J
b) v=14 m/s
c) vT=96m/s and the differential equation --> v(t)= sqrt(vT(1-Ce^(-gt/(2v/vT))))
d) C=arctanh 0= 0
x(t)=sqrt(a/mg)*v*t
x(7.16)=10.13 m
billy_joule said:
Do you have a question?
well, sort of. I have calculated each problem, but i am not sure if the results are right?
In a), there are two questions, but you only provided one answer.
In c), I don't understand how you got such a large terminal velocity from the given data. Maybe you wrote out the question details wrongly.
In c), you are asked for the differential equation. You appear to have answered with the solution to the equation instead.
In d), you are asked for x as a function of t, but your answer also has a variable v in it. (I have not checked whether your answer is a correct statement.)
How did you get 96m/s in c, i believe that is wrong, and how did you find the diff eq. for v(t)
The differential equation is
dv/dt=g+a/m*v^2. If you solve it you will get the terminal velocity 9.90 m/s, so i think it is right
You can find terminal velocity putting mg-av^2=0 and solve for v. In b you got 14 without friction. Since we have friction, the terminal velocity has to be less then 14 m/s
Well, I've calculated the fall numerically. Here are the results (attached):
So I find that x(1.6728s ) = 10.00213m
That doesn't follow. The 14 was not a terminal velocity, it was still accelerating. With very small drag, the terminal velocity coild have been more.
That said, I agree with your answer. (It must be quite a large box for its mass.)
On a), wouldn't the work be 0 since you do it in a 90 degree. W=F*s*cos90=0
I don't understand. Where are you getting an angle of 90 degrees from. Angle between what force and what displacement?
My bad. The angle between the force and the displacement is of course 0 degree.
