How Quickly Does Ice Form on a Pond at -10°C?
  • Thread starter Thread starter ice87
The discussion focuses on calculating the rate of ice formation on a pond at -10°C, specifically addressing a scenario where a 1cm thick layer of ice is present. The density of ice is noted as 0.917g/cm³, and its thermal conductivity is 0.592 W/mK. Key considerations include the location of ice formation at the bottom of the layer due to the temperature at the ice/water interface being below freezing. The use of integrals is suggested for solving the problem, particularly in determining the time required for a 20cm layer to build up.
  • Understanding of thermal conductivity and its implications in heat transfer
  • Knowledge of the properties of ice, including density and phase changes
  • Familiarity with calculus, specifically integrals for rate calculations
  • Basic principles of heat transfer in fluids
  • Study the principles of heat transfer in materials, focusing on thermal conductivity
  • Learn about the mathematical application of integrals in physical scenarios
  • Research the effects of temperature on phase changes in water and ice
  • Explore real-world examples of ice formation in natural bodies of water
Students in physics or environmental science, researchers studying ice dynamics, and anyone interested in the thermal properties of water and ice formation processes.
ice87
difficult problem, need URGENT help
A small pond has a layer of ice 1cm thick floating on its surface. (a) If the air
temperature is −10C, find the rate in cm per hour at which ice is added to the layer. The density of ice is 0.917g/cm3 and its thermal conductivity is 0.592 W/mK. (b) How long does it take for a 20cm layer to build up?
I think this problem requires the use of integrals. I don't know how to do that. I don't understand this problem AT ALL, so please help me out here.
no one??
Some things to consider to get you thinking in the right direction.
1. Where is the ice being added? Bottom, because that's where the water is.
2. Why is ice added to the bottom? Because the temperature at the ice/water interface is below freezing.
3. What is the temperature of the ice/water interface? Depends in the heat transfer from the top of the ice through the ice to the bottom of the ice.
4. Consider a small thinkness of ice, dt forming at the ice/water interface, so small, in fact, that it has the same temperature as the ice/water interface.
  • · Replies 24 ·
10K
