How should I simplify this product expression?
The discussion focuses on simplifying a product expression that varies based on whether n is even or odd. For even n, the product can be expressed as 2n/(n+1), while for odd n, the denominator changes, complicating the expression. Participants suggest analyzing the product by writing out terms and identifying patterns, with one noting that many factors cancel out. The use of factorials is proposed to further simplify the expression, leading to a final solution that retains only the outer terms. Ultimately, the conversation emphasizes the importance of recognizing patterns and using mathematical induction for proof.
musicgold
I need to simplify the following product expression and show it in factorial terms.
As shown below I have calculated the value of bn for 10 terms.
I see that when n is an even number, the product can be represented as ## \frac {2n} {(n+1)} ##. When n is an odd number, the denominator seems to be changing and I am not able to define an expression for it.
How should I go about solving this?
Thanks
The equality also seems to hold for odd n:
##b_3 = 2.3/(3+1) = 6/4 = 3/4##
##b_5 = 2.5/(5+1) = 10/6 = 5/3##
and so on.
Likes musicgold
and so on.
Oh..I totally missed it. Thanks.
How would a trained mathematician go about analyzing this kind of question? Would they do what I did - analyzing a first few steps?
6/4 = 3/2
Likes musicgold
Write a few of the terms. If I start with ##P_4## (the product of the first three factors), I get
##\frac 4 3 \frac 9 8 \frac {16}{15} = \frac{2^23^34^2}{3\cdot8\cdot15}##
The numerator can already be expressed in terms of factorials, but I don't think the denominator can.
Likes musicgold
Yes, the denominator can ... well almost.
Factor the denominator. ##(k-1)(k+1)##Write out a few terms.
Likes musicgold
There are many factors that cancel numerator and denominator. I would write down some factors and see what cancels and what is left. Probably a lot cancels and if you are lucky, all you would be left with are at the beginning and the end.
Likes musicgold
I would do it the way you did, and hope I saw a pattern. Of course, one then has to prove this pattern is correct. For this, you can use induction.
Likes musicgold
if we take 3 successive terms we ll have
$$\frac{(k-1)(k-1)}{(k-2)k}\frac{kk}{(k-1)(k+1)}\frac{(k+1)(k+1)}{k(k+2)}$$ and after simplifications we are left with the two terms in the edges ##\frac{k-1}{k-2}## and ##\frac{k+1}{k+2}## which will get simplified by the previous and next terms so the total product will have all intermediate terms simplified to 1 and only the two outer-outer terms will survive which are the terms ##\frac{2}{1}## and ##\frac{n}{n+1}## giving the final solution $$\frac{2n}{n+1}$$
Likes musicgold and FactChecker
SammyS said:
Yes, the denominator can [be written as factorials] ... well almost.
Supposing you are interested in solving this with factorials, you might find it helpful to do the following prior to writing out a few terms.
Rewrite the product as follows.
##\displaystyle b_n = \prod_{k=2}^n {\ \dfrac{k^2}{k^2-1}} ##
## = \dfrac{\displaystyle \left( \prod_{k=2}^n k \right) \left( \prod_{k=2}^n k \right) }{\displaystyle \left( \prod_{k=2}^n (k-1) \right) \left( \prod_{k=2}^n (k+1) \right) } ##​
Write out a few terms, or do the general expanded expression using ellipses (...) .
Likes Delta2 and FactChecker
Cool!
So if I understand this correctly, all terms except ## \left( \prod_{k=2}^n (k+1) \right) ## can be converted into factorials, because the lowest term of that product will be 3. Is that correct?
musicgold said:
Cool!
That can be converted to factorial too, it is equal to ##(n+1)!/2##
Likes musicgold and SammyS
Great! Thanks
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 17 ·
