How should one interpret ##\vec{f}=0## in an ideal battery?
The discussion centers on the interpretation of the equation ##\vec{f}=0## within the context of an ideal battery. It is established that inside an ideal battery, the electrostatic field ##\vec{E}## and the electric field produced by chemical reactions ##\vec{f_s}## oppose each other, resulting in a net force ##\vec{f}## of zero. This does not imply that charges are stationary; rather, they move at a constant speed in a straight line. When a circuit is closed, the net electric field changes, allowing current to flow as the charges are pushed through the battery.
  • Understanding of electrostatics and electric fields
  • Familiarity with circuit theory and current flow
  • Knowledge of chemical reactions in batteries
  • Basic concepts of force and motion in physics
  • Study the principles of electrostatics and electric fields in detail
  • Learn about the behavior of charges in circuits, particularly in closed circuits
  • Investigate the role of chemical reactions in battery operation
  • Explore Newton's laws of motion as they apply to charged particles
Physics students, electrical engineers, and anyone interested in understanding the dynamics of charge movement in batteries and circuits.
ghostfolk
In a circuit there are two forces that act on the charges to keep the current uniform through out,
##\vec{f}=\vec{E}+\vec{f_s}##, where ##\vec{E}## is the electrostatic field and ##\vec{f_s}## is the electric field produced by chemical reactions. Inside an ideal battery, ##\vec{E}## and ##\vec{f_s}##, oppose each other such that ##\vec{f}##, is zero. What exactly would be the correct way of thinking of ##\vec{f}=0##? I mean obviously the charges are moving, but it looks like in the battery they are not.
I don't think that this is a correct analysis, but f=0 would imply that the charge is not accelerating rather than that it is not moving.
I got it from Griffiths' Introduction to Electrodynamics. I know that would imply the charges are still moving, but how do I know that current is being produced?
Current = charges moving. They are the same thing. If you know that the charges are moving then you automatically know that there is current.
But if the net force on the charges are zero, shouldn't the charges move about randomly cancelling out any current?
No. If the net force is zero then they continue in a straight line at a constant speed.
So how do I know they started in a straight line?
ghostfolk said:
Inside an ideal battery, E⃗ \vec{E} and fs→\vec{f_s}, oppose each other such that f⃗ \vec{f}, is zero.
Yes, but the moment you close a circuit on the outside of the battery, the current reduces the charge and thereby the electric field. The net field will then be different from 0 and start pushing charges through the battery.
Ohh okay. You see in the textbook I was reading, it made no distinction as to whether or not the circuit was open.
  • · Replies 51 ·
9K
  • · Replies 16 ·
