How Should the Parabolic Dish Be Aligned for Optimal Radio Wave Reception?
The discussion revolves around optimizing the alignment of a parabolic radio telescope dish to maximize radio wave reception. Participants explore the geometric properties of the parabola, including the focus, directrix, and vertex, and their relationship to the reception of radio waves.
  • Participants inquire about the optimal placement of the focus, directrix, and vertex of the parabola in relation to the Cartesian plane. Questions arise regarding the positioning of the radio receiver and the dish's orientation relative to the radio source.
Some participants have provided insights into the theoretical aspects of parabolic antennas and the importance of placing the receiver at the focus. However, there is ongoing exploration of specific configurations and assumptions regarding the radio source and dish setup.
Participants note a lack of specific information about the radio source and its characteristics, which may impact the discussion on optimal alignment and setup. There are also references to various types of parabolic antennas and their operational principles.
rqyytrf
Parabolic radio telescope. Dish is fixed and across its centre a cable is suspended carrying a beam on which equipment is mounted to pick up radio waves.
Basically it's just a parabola on the cartesian plane.
How would you adjust the parabola ( focus, directrix, vertex etc ) so that the maximum intensity radio waves may be intercepted.
and any other ways such as size of dish or position of beam etc.
Thanks
N/A more of a worded problem
I can find information about how the size of the dish would maximize the wave intensity etc but nothing specific which is what I am looking for.
Where should the focus be on the cartesian plane? e.g How far up the y axis? How far across the x axis?
Same question for the directrix as they relate to each other ^^
Should the vertex be at the origin of the cartesian plane? Or shifted to another point? which?
Thanks
How would you adjust the parabola ( focus, directrix, vertex etc ) so that incoming radio waves are at their maximum intensity?
Not enough information.
i.e. where and what sort of radio source is it?
However;
in general - how do you use a parabolic dish to receive radio waves?
Where would you point the dish relative to the direction of the radio source?
Where would you put the radio-receiver in terms of the geometry of the dish?
I cannot tell what question you are asking in "attempt 2".
However;
Edited original post
Cool: that is clearer ... questions still the same.
i.e. the equipment to pick up radio-waves ... where should you put that to get best reception?
The only information i was able to find was about what types of parabolic antennas there are. So far the only thing i can come up with is to adjust the focal point so it is directly opposite the bottom of the dish (Move the focus further up the y axis). This would increase the latus rectum and therefore will be at it's maximum diameter. This larger diameter would then be applied to Area and Volume rules ( for the dish ) which would increase the reception of incoming radio waves.
I'm still wondering about the vertex though... (i seriously can't find any more)
Should the vertex be at the origin or shifted somewhere else (h,k)? Stuff like this.
There are many parabolic radio antennas all over the world. The biggest that I know of is at the Arecibo Observatory in Puerto Rico. I am pretty sure the fixed dish is parabolic although spherical reflectors will work also. For best reception the actual radio receiver should be placed at the focus of the parabola. If the dish is fixed, then the pointing can be changed a little by moving the location of the "sky room" Go look at the Arecibo Observatory website. Theoritically, all of the RF energy that hits the dish will be reflected into the receiving antenna located at the focus. Most parabolic antennas operate in the microwave region, i.e. 2 - 32 GHz. The TV satelite antenna you see all over the place are a section of a true parabolic antenna, not the entire surface of revolution. The receiving element is or should be at the focus. All of the antennas that trackl the Deep Space satelites are operated by the Jet Propulsion Laboratory. You can go to their website and search for the DSN, meaning the Deep Space Network, or merely google DSS-14 and see what you get.
Only where the source is approximately plane waves.
But that is pretty much how people set up the dish IRL - the radio-wave receiving stuff goes at the focus of the dish.
@rqyytrf: forget about looking stuff up for a bit - just think of the dish as a big concave mirror ... you want light (the radio waves) to concentrate on the apparatus at the end of the boom ... what do you do? You know this one already.
You can adjust the shape of the mirror (affects focal length and directrix), and you can adjust which way the dish points by turning it.
  • · Replies 69 ·
