How simplifying this ratio test for series?
15 replies · 7K views · last reply
frasifrasi
[SOLVED] How simplifying this ratio test for series?
Basically, we are asked if (n!n^2)/(2n)! converges absolutely...
I got to the point where
lim as n --> infinity of
[(n+1)!(n+1)^2]/(2(n+1))! X (2n)!/n!n^2
by the ratio test.
But I don't know how to manipulate the factorials from here on...could anyone help?
Thank you.
(n+1)!=(n+1)n! which should cancel with the n!
2(n+1))! =(2n+2)!=(2n+2)(2n-1)!
(2n)!=2n(2n-1)!
You could replace the factorials with their respective Stirling approximations, which is asymptotic to the factorial function, ie as n grows large the quotient of the approximation and the factorial approaches 1.
(My earlier idea was wrong because I compared with a divergent series, but adapted slightly and if you're allowed to assume the convergence of zeta(2), the following might do the trick simply).
For large n, the denominator (2n)! = (n+n)! >> (n+4)! = n!(n+1)(n+2)(n+3)(n+4) > (n!)n^4
Cancel off the numerator and you're left with terms that are strictly less than 1/n^2 for large n. By the limit comparison test with zeta(2), this converges.
I see, does anyone know a place I can look up these formulas?
rock.freak,
for the (2n+2)!, shouldn't it be (2n+2)(2n+1)! ... because you keep subtracting 1??
And can anyone please evaluate this series...I am getting stuck at the end with
lim as n --> infinity of (n+1)^2/n.
Thank you.
I assume you are look at the convergence of
[tex]\sum_n \frac {n!n^2}{(2n)!}[/tex]
Applying the ratio test, you want to determine
[tex]\lim_{n\to\infty}\frac {(n+1)!(n+1)^2}{(2(n+1))!}\frac {(2n)!}{n!n^2}[/tex]
First expand the factorials: [itex](n+1)!=(n+1)n![/tex] and [itex](2(n+1))!=(2n+2)(2n+1)(2n)![/tex]. Inserting these in the limit expression yields<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)n!(n+1)^2}{(2n+2)(2n+1)(2n)!}\frac {(2n)!}{n!n^2}[/tex]<br /> <br /> Simplifying,<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)^3}{(2n+2)(2n+1)n^2}[/tex]<br /> <br /> Most of the remaining terms cancel in the limit. For example,<br /> <br /> [tex]\lim_{n\to\infty}\frac{n+1}{n} = 1+\lim_{n\to\infty}\frac{1}{n} = 1[/tex][/itex][/itex]
frasifrasi said:
rock.freak,
Yes it should...I made a mistake
I still don't see how you evaluate that last (n+1)^3 limit, though.
DH, did you expand the terms or cancel something out?
Thank you everyone for the great help.
The only terms I canceled were [itex]n!/n![/itex] and [itex](2n)!/(2n)![/tex]. I left the evaluation of<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)^3}{(2n+2)(2n+1)n^2}[/tex]<br /> <br /> up to you, with a very strong hint in<br /> <br /> [tex]\lim_{n\to\infty}\frac{n+1}{n} = 1[/tex]<br /> <br /> I guess the hint wasn't quite enough. Just drop the +1/+2 terms: change [itex](n+1)^3[/itex], [itex]2n+2[/itex], and [itex]2n+1[/itex] to [itex]n^3[/itex], [itex]2n[/itex], and [itex]2n[/itex], respectively.[/itex]
I see, so I would get [tex]\lim_{n\to\infty}\frac{n^3}{2n.2n.n^2}[/tex]
SO, here I cancel the n^3 with the n^2, correct, getting n/(2n)(2n) -- Don't I get zero??
A little more effort on your part and I am on my way to grasping this. Thanks.
Yes, the ratio test limit is [itex]\lim_{n\to\infty}1/(4n)=0[/itex]. The series converges.
but, how/why did you get 1 in your previous post?
That was not the same limit. That was
[tex]\lim_{n\to\infty}\frac{n+1}{n}[/tex]
which is indeed one but is also quite different from
I see you were just providing an example? that actually confused me a lot because i thought it was the next sterp.
Thanks for the help!
I guess what i get is 1/4n, which goes to zero.
That's why I said "Most of the remaining terms cancel in the limit. For example,"
You're welcome. I'm marking this as solved.
