How simplifying this ratio test for series?
15 replies · 7K views
frasifrasi
[SOLVED] How simplifying this ratio test for series?
Basically, we are asked if (n!n^2)/(2n)! converges absolutely...
I got to the point where
lim as n --> infinity of
[(n+1)!(n+1)^2]/(2(n+1))! X (2n)!/n!n^2
by the ratio test.
But I don't know how to manipulate the factorials from here on...could anyone help?
Thank you.
You could replace the factorials with their respective Stirling approximations, which is asymptotic to the factorial function, ie as n grows large the quotient of the approximation and the factorial approaches 1.
(My earlier idea was wrong because I compared with a divergent series, but adapted slightly and if you're allowed to assume the convergence of zeta(2), the following might do the trick simply).
For large n, the denominator (2n)! = (n+n)! >> (n+4)! = n!(n+1)(n+2)(n+3)(n+4) > (n!)n^4
Cancel off the numerator and you're left with terms that are strictly less than 1/n^2 for large n. By the limit comparison test with zeta(2), this converges.
I see, does anyone know a place I can look up these formulas?
rock.freak,
for the (2n+2)!, shouldn't it be (2n+2)(2n+1)! ... because you keep subtracting 1??
And can anyone please evaluate this series...I am getting stuck at the end with
lim as n --> infinity of (n+1)^2/n.
Thank you.
I assume you are look at the convergence of
[tex]\sum_n \frac {n!n^2}{(2n)!}[/tex]
Applying the ratio test, you want to determine
[tex]\lim_{n\to\infty}\frac {(n+1)!(n+1)^2}{(2(n+1))!}\frac {(2n)!}{n!n^2}[/tex]
First expand the factorials: [itex](n+1)!=(n+1)n![/tex] and [itex](2(n+1))!=(2n+2)(2n+1)(2n)![/tex]. Inserting these in the limit expression yields<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)n!(n+1)^2}{(2n+2)(2n+1)(2n)!}\frac {(2n)!}{n!n^2}[/tex]<br /> <br /> Simplifying,<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)^3}{(2n+2)(2n+1)n^2}[/tex]<br /> <br /> Most of the remaining terms cancel in the limit. For example,<br /> <br /> [tex]\lim_{n\to\infty}\frac{n+1}{n} = 1+\lim_{n\to\infty}\frac{1}{n} = 1[/tex][/itex][/itex]
frasifrasi said:
rock.freak,
Yes it should...I made a mistake
I still don't see how you evaluate that last (n+1)^3 limit, though.
DH, did you expand the terms or cancel something out?
Thank you everyone for the great help.
The only terms I canceled were [itex]n!/n![/itex] and [itex](2n)!/(2n)![/tex]. I left the evaluation of<br /> <br /> [tex]\lim_{n\to\infty}\frac {(n+1)^3}{(2n+2)(2n+1)n^2}[/tex]<br /> <br /> up to you, with a very strong hint in<br /> <br /> [tex]\lim_{n\to\infty}\frac{n+1}{n} = 1[/tex]<br /> <br /> I guess the hint wasn't quite enough. Just drop the +1/+2 terms: change [itex](n+1)^3[/itex], [itex]2n+2[/itex], and [itex]2n+1[/itex] to [itex]n^3[/itex], [itex]2n[/itex], and [itex]2n[/itex], respectively.[/itex]
I see, so I would get [tex]\lim_{n\to\infty}\frac{n^3}{2n.2n.n^2}[/tex]
SO, here I cancel the n^3 with the n^2, correct, getting n/(2n)(2n) -- Don't I get zero??
A little more effort on your part and I am on my way to grasping this. Thanks.
but, how/why did you get 1 in your previous post?
I see you were just providing an example? that actually confused me a lot because i thought it was the next sterp.
Thanks for the help!
I guess what i get is 1/4n, which goes to zero.
