What is the boiling point of blood at low air pressure?
The boiling point of blood is significantly affected by air pressure, with the saturation temperature of water at 0.04 bars being approximately 29.0°C (84.1°F). At normal body temperature of 37°C (98.6°F), blood would boil if the pressure drops to 0.04 bar, which is above a complete vacuum. The discussion highlights the relationship between atmospheric pressure and the boiling point, emphasizing that a sudden loss of atmospheric pressure would lead to severe physiological consequences, including boiling of blood and lung collapse.
  • Understanding of atmospheric pressure and its measurement (e.g., pascals, bars).
  • Basic knowledge of the physical properties of water and blood.
  • Familiarity with the concept of boiling point and its dependence on pressure.
  • Awareness of the physiological effects of rapid decompression.
  • Research the effects of low atmospheric pressure on human physiology.
  • Study the principles of fluid dynamics related to pressure changes.
  • Learn about the thermodynamic properties of water and blood.
  • Investigate safety protocols for handling pressurized containers, such as scuba tanks.
Physicists, medical professionals, safety engineers, and anyone interested in the effects of pressure on biological systems.
BigMacnFries
I have read that air pressure is about 100,000 pascalls
which = 100,000 Newtons/m2
which is enough to accelarate a 1kg body with a surface area of 1m2 to 100,000 m/s in one second
which is enough to accelarate a 100kg body with a surface area of 1m2 to 1000m/s in one second.
Is this right. Since i am about 100kg and have a front body surface of about 1m2 is it true that if the air pressure on my back suddenly dissaperaed I would be 1km that way in a little over a second?
An object with a one-meter-squared side experiences a little over a hundred thousand Newtons of force, over that area, due to atmospheric air pressure.
If there were absolutely no opposing forces, such an object with a mass of only 1 kg would experience an acceleration of a little over 100,000 m/s^2.
Of course, it would be quite a feat to arrange a system in which the pressure did not change at all as the object were accelerated. Consider a potato gun or pneumatic rifle. As the projectile begins moving, the cavity behind it gets larger, and the pressure in that cavity is reduced. When fired with atmospheric pressure into a vacuum, the projectile would experience that 100,000 m/s^2 acceleration only instantaneously at the beginning of its movement; at all later times the acceleration would be much less.
Anecdotally, air pressure can store very large amounts of energy. A scuba tank exploding inside a dive shop, for example, can pretty much destroy the whole shop.
- Warren
chroot said:
Anecdotally, air pressure can store very large amounts of energy. A scuba tank exploding inside a dive shop, for example, can pretty much destroy the whole shop. [emphasis added]
"Anecdotally"? Did you really think we could let that go without expansion (pun weak, but intended)?
You would not want to be in your body if the Earth suddenly lost its measly 15 psi atmosphere. Your blood would boil, lungs collapse... and it gets ugly after that.
Why would my blood boil etc?
Boiling point is dependent on pressure.
Blood is mostly water.
The saturation temperature of water at 0.04 bars (1 atm = 1.01325 bar = 14.696 psia) is 29.0°C (84.1°F). So if the temperature of blood is about 98.6°F (37°C), the blood would boil at 0.04 bar, which is still greater than vacuum (<<0.01 bar).
  • · Replies 169 ·
15K
