How High Is the Bridge Based on Projectile Motion?
  • Thread starter Thread starter keithcuda
    Bridge
The problem involves calculating the height of a bridge based on the horizontal distance a rock travels when thrown horizontally. Given that the rock hits the water 30 meters away and is in the air for 2 seconds, the correct formula to use is d = 0.5 * g * t², where g is the acceleration due to gravity (9.8 m/s²). The calculation yields a height of 19.6 meters for the bridge, confirming that the initial assumption was correct. The confusion arises from misinterpreting the distance traveled in the first second versus the speed at that moment.
  • Understanding of projectile motion principles
  • Familiarity with the equations of motion, specifically d = 0.5 * g * t²
  • Knowledge of gravitational acceleration (9.8 m/s²)
  • Basic algebra for solving equations
  • Study the concepts of vertical and horizontal motion in projectile motion
  • Learn about the effects of air resistance on projectile trajectories
  • Explore advanced projectile motion problems involving angles
  • Investigate real-world applications of projectile motion in physics
Students studying physics, educators teaching projectile motion, and anyone interested in understanding the dynamics of objects in motion.
keithcuda
A rock thrown horizontally from a bridge hits the water below 30 meters away in the horizontal direction. If the rock was in the air for 2 seconds, how tall is the bridge?
d=.5gt2
I think I am going about this the right way. Just want to double check.
d=.5*9.81*4
d= 19.62m
The bridge would be 19.62m high?
cheers,
Keith
It's been about 50 years since I've actually worked out a problem like that but it sounds wrong, and here's why: the acceleration due to gravity is 9.8 meters per second per second. That means that the rock will travel 9.8 meters in the first second, but much more in the next second, so the total can't be 9.8 x 2 which is what you got.
It looks right to me. The first second it travels ~ 5 m, and the second second, it travels ~15 m.
Chet
Likes keithcuda
Chet
Guess I have it wrong then that it travels 9.8m in the first second. I guess what the figure means is that at the end of the first second it is MOVING at 9.8 m/s, not that it has MOVED 9.8 m ... 50 years ago I bet I would have got it right :oldtongue:
18K
