How the heck do I integrate this?
  • Context: Graduate
  • Thread starter Thread starter yuiop
    Integrate
4 replies · 3K views
yuiop
Hi,
I am trying to find a solution for this equation in terms of r or t:
[tex]\frac{d^2r}{dt^2} = \frac{m}{r(r-2m)}\left( \left( \frac{dr}{dt}\right)^2-\left(1-\frac{2m}{R}\right)\right)[/tex]
It seems I should integrate it twice with respect t, but I have no idea how to do that with a dr/dt term in the middle of the right hand side. I need to get rid of all dr and dt variables and obtain an answer that contains just r,t and R variables, if that is possible.
One possible (given) solution that I am not convinced is correct is:
[tex]t=\frac{R}{2}\sqrt{\frac{R}{2m}}\left(cos^{-1}\left(\frac{2r}{R}-1\right)+2\sqrt{\frac{r(R-r)}{R^2}}\right)[/tex]
but I have no idea how the solution was obtained.
Since the independent variable [itex]t[/itex] doesn't appear, try the substitutions [itex]dr/dt = p[/itex] and
[tex]\frac{d^2 r}{dt^2} = \frac{dp}{dt} = \frac{dr}{dt} \frac{dp}{dr} = p \frac{dp}{dr}.[/tex]
Hi George,
I am still getting nowhere with this derivation and maybe you could provide some more hints?
Here is some some more info:
The equation that I am looking for the derivation of is actually given as a parametric equation
[tex]r = \frac{R}{2}(1+cos(\alpha)) , \tau = \frac{R}{2}\sqrt{\frac{R}{2m}}(\alpha+sin(\alpha))[/tex]
on this mathpages page http://www.mathpages.com/rr/s6-04/6-04.htm
and the equation it is derived from appears to be equation (5) on that page.
Any ideas?
Putting aside the complicated coefficients, letting p= dx/dt as George Jones suggested,
the equation becomes pdp/dx= A(p2- B) which is equivalent to
[tex]\frac{p dp}{Ap^2- B}= dx[/tex] which is easy to integrate.
Once you have found p= dx/dt, integrate again.
[tex]\frac{p dp}{A(p^2- B)}= dx[/tex] which is easy to integrate.
Is this on the right track?
[tex]p \frac{dp}{dx} = A(p^2-B)[/tex]
[tex]p^2 = \int{A(p^2-B)}dx = C[x,p][/tex]
where C[x,p] is some function of x and p.
Solve for p
[tex]p = D[x] = \frac{dx}{dt}[/tex] (assume t is shorthand for proper time tau)
[tex]x = \int{ D[x] } dt = E[x,t][/tex]
Solve for x or t
[tex]x = F[t][/tex] or [tex]t = G[x][/tex]
I also need to know if a indefinite integration is OK for the first integration or if a definite integration is more rigorous. When I try a definite integral
[tex]\int_{0}^{R} {A(p^2-B)} dx[/tex] or [tex]\int_{2m}^{R} {A(p^2-B)} dx[/tex]
the software complains about division by zero errors. Presumably that is singularity problems at x=0 and x=2m?
Should I allow for the constant of integration at the first integration or just add one in at the final integration?
I hope that makes some sort of sense. I am a bit out of my depth here and need all the help I can get from you guys ;)
P.S. I am aware some of these problems can be made a lot simpler if a parametric form can be found before integration. Is the parameter [itex]\alpha[/itex] in the mathpages parametric equation the same as the p = dr/dt introduced by George?
