How to add four arctangents efficiently
  • Thread starter Thread starter mgamito
2 replies · 3K views
mgamito
I need to compute the addition of four arctangents:
[itex]\alpha = \arctan(x_1) + \arctan(x_2) + \arctan(x_3) + \arctan(x_4)[/itex]
Rather than call four arctangent functions, I was thinking of using the arctangent addition formula:
[itex]\arctan(u) + \arctan(v) = \arctan(\frac{u + v}{1 - uv}) + \pi n[/itex], for some [itex]n \in N[/itex]
I could invoke the above property three times and I would only have to call the arctan function once. My problem is how to keep track of the integer [itex]n[/itex] throughout so that the result is correct.
My initial variables [itex]x_1[/itex] to [itex]x_4[/itex] are all positive so the result should be an angle [itex]0 \leq \alpha < 2\pi[/itex]. I suspect the answer lies in keeping track of the sign of the [itex]1 - uv[/itex] denominators and introducing some factor of [itex]\pi[/itex] correction if they go negative.
I'll work this through the weekend but I thought I would post this here in case someone figured this out already.
Thank you,
manuel
on Phys.org
maybe this can help you
http://www.enotes.com/homework-help/evaluate-value-this-expression-arctan-1-3-arctan-1-251223
Thank you,
manuel
If ##\arctan(x_1) + \arctan(x_2) = \arctan(y_1) + \pi n_1## and ##\arctan(x_3) + \arctan(x_4) = \arctan(y_2) + \pi n_2,## we then have ##\sum_{i=1}^4 \arctan(x_i) = \arctan(y_1) + \arctan(y_2) + \pi (n_1 + n_2),## which has the form ##\arctan(z) + \pi (n_1 + n_2 + n_3).## Here,
[tex]z = \frac{y_1 + y_2}{1-y_1 y_2}.[/tex]
We might as well just say that ##n_1 + n_2 + n_3 = n,## an integer.
