How to attach bearings on shaft
  • Thread starter Thread starter Blad9
    Shaft
To attach bearings to a shaft that needs to rotate 90 degrees, two slide bearings can be positioned at the top and bottom for rotation. Vertical movement can be stabilized using external circlips if there is no axial load, or by creating a shoulder on the shaft for support if axial forces are present. The middle portion of the shaft can be thicker than the ends, which may require specific fitting techniques such as press fitting or thermal expansion. Understanding the mechanics of a bicycle crank can provide useful insights for this setup. Consulting structural design books related to gearboxes can further aid in the process.
Blad9
I have a shaft, which I would like to rotate 90 degrees to one side and then 90 degrees back to the other side and so forth. How should I attach the bearings to this shaft? I was thinking to do it as shown in this image:
Two slide bearings, one on the top and one on the bottom so the shaft can rotate. But how should I fix this movement vertically? I’m completely new to attaching bearings on shafts, so any help would be appreciated. It does not necessarily have to be done as shown in the image.
The shaft at the middle portion can be thicker in diameter than the top and bottom portion.
Yes, true. Didn't think about that. But how should I realize that?
If there is no axial load, you can use external circlips
if there is a load, perhaps you could look at the workings of a crank on a bicycle. Are you attaching anything to each end of the shaft? some shafts are frozen (reduced in size) then feed into the bearing and gradually heated to create a mate through expansion of metal, or you can have them press fitted.
Hope this helps.
Dunk
if you need the shaft bears axial force, the shaft must have a shoulder, one bearing leans against the shoulder, it can support whole shaft.
i suggest you refer to some books show a few structure inside gear box, it is useful for you.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
