How to balance chem.eq. with crystal water?
The discussion focuses on balancing the chemical equation for the reaction between iron (Fe) and sulfuric acid (H2SO4) to form iron(II) sulfate heptahydrate (FeSO4*7H2O). The balanced equation is Fe + H2SO4 + 7H2O → FeSO4*7H2O + H+. Participants emphasized the importance of including water molecules in the reaction to account for the crystal water in the product. The mole ratio between Fe and FeSO4*7H2O is 1:1, allowing for straightforward calculations based on the mass of iron used.
  • Understanding of stoichiometry and mole calculations
  • Familiarity with balancing chemical equations
  • Knowledge of hydration in chemical compounds
  • Basic principles of acid-metal reactions
  • Study the principles of stoichiometry in chemical reactions
  • Learn about hydration and the role of water in crystallization
  • Explore acid-base reactions involving metals
  • Practice balancing complex chemical equations with hydration
Chemistry students, educators, and anyone interested in mastering chemical reactions involving hydration and stoichiometry.
eventob
10 g Fe and x ml H2SO4 forms y gFeSO4*7H2O
Write a balanced chemical equation for the reaction, and determine the coeffisients y and x. The H2SO4 is 1 M.
n=V*c
n=m/Fm
First thing I was trying to set up the chemical eq:
Fe+H2SO4 => FeSO4*7H2O
But, I'm not sure how to balance the hydrogens and oxygens in the crystal water.
I've also calculated the how many moles 10 g of Fe is.
Any thoughts?
Thanks in advance.
You need to add water molecules on the left - after all, reaction takes place in a solution. If not, there is no way hydrated salt can be produced.
Thanks.
But then, do I have to add hydrogen to the right?
Fe+H2SO4 + 7H2O => FeSO4*7H2O + H^+
Other than water of crystallization it is not different from the reaction between a metal and an acid. I am more than sure that you have covered this reaction earlier, so check your notes and the book. Googling for reaction between metal and acid will also give you the answer.
Thanks again. :)
I tried to Google it first, but could only find formulas without the crystallization water. So I was not sure how to handle that part. I am currently taking two different chemistry courses, one introductory and one who builds one the knowledge from the introductory course. I've never seen the *H2O part until this reaction. :)
Writing a balanced reaction should be no big problem. Look at the mole ratios among the parts and the materials. Post #3 reaction is almost, but not yet balanced. No matter, you can still write enough reaction without including the H+ ions.
Use given information and formula weights to account for both grams and moles.
10 grams Fe ----- How many moles?
1 to 1 mole ratio of Fe to FeSO4*7H2O ----- then how many moles and how many grams if starting from 10 grams of Fe ?
