B How to calculate a perpendicular line?
To calculate a perpendicular line from two given points, first determine the slope of the line connecting those points using the formula (y2-y1)/(x2-x1). The slope of the perpendicular line is the negative reciprocal of this slope. While you can find the equation of the original line in slope-intercept form (y = mx + b), there are infinitely many perpendicular lines unless a specific intersection point is defined. The y-intercept (b) for the perpendicular line can vary, depending on where you want it to intersect the original line. Understanding these relationships allows for the calculation of various perpendicular lines based on the initial coordinates.
msn009
Hi, i get the math that is involved but if I have only the x,y coordinates for 2 points to connect and if i want to know what will be the perpendicular line to the line connecting these two points, how can I do that?
Mathematics news on Phys.org
I presume, given those points, that you can find the equation of the line connecting them and its slope. Given that, you can find the slope of the line perpendicular to that one. But there are many such lines.
yes there will be many possible lines.
when i mentioned that i understand the math, the examples given usually has numbers in it like y = 3x+2 but in my case i only have the x and y values, so which formula should i actually use? thanks.
That's the slope-intercept form of the equation for a line: y = mx + b, where m is slope and b is the y-intercept. (Look it up!)
Start by finding the slope.
Find the slope connecting those two points (y2-y1/x2-x1). The perpendicular line is the negative inverse.
If the equation of your two points are y = mx+b, the perpendicular line to that will be every line that is
y = -(1/m)x+n where n ∈ ℝ
(Since you only care about if they are perpendicular or not and the line streches infinitely)
The slope of a line perpendicular to another line is just the negative reciprocal of the slope of the other line.
So, if you have a line where m=2, the slope of a line perpendicular to that line would be m=-1/2.
Likes YoungPhysicist
If you have the equation of a line it is pretty simple to find a couple of points on that line.
If you have a couple of points on the line, it is pretty simple to find the equation of that line.
So whether you are starting from the equation o f the line or a couple of points on the line, there is only one extra step to the problem.
i have a line that connects from point A to point B and I am able to compute this line using its x,y coordinates and so now i need to find the slope of this line so that i can compute the line that will be perpendicular to this line.
Use the definition of slope, which was given in an earlier post. Or just look it up! https://en.wikipedia.org/wiki/Slope
i get this part and i have compute the slope of the line from point A to B. what I don't understand now is the intercept value y=mx + b. I can compute the b value since I now have x, y and m values but should I use this same b value to compute the perpendicular line?
As explained above, given two points you can find the equation of the line that connects them. But there is an infinite number of lines perpendicular to that one. Do you want that perpendicular line to intersect the first line at some particular point? Up to you!
