How to Calculate Average Speed Using Parametric Equations
8 replies · 13K views · last reply
keemosabi
Can someone please tell me how to get the average speed of a particle moving along a path represented by parametric equations? Is it [itex]\frac{1}{b-a}\int_{a}^{b}\sqrt{\frac{dx }{d t}^2 + \frac{d y}{d t}^2}[/itex]
Isn't this the arc length formula?
This is the arc length formula. The average value formula is Favg=(1/b-a)INT[f(x)dx]. It seems you combined two formulas.
But if I wanted the speed of a particle moving with a parametric graph, woldn't everything under the radical be my speed function?
Actually, you may be right. I think that might actually work.
No, no, no. The average speed is displacement over time. It has nothing to do with arc length. It's sqrt((x(b)-x(a))^2+(y(b)-y(a))^2)/(b-a) where a is the intiial time and b is the final time. Right?
Couldn't you also do the average value of the absolute value of the velocity graph?
Yes, you could. In which case that would be correct. Distance travelled/time could also be considered an average speed. I was only thinking of the displacement/time definition.
Alirght, thank you for the help.
Also, is there any way to determine if a particle traveling on a parametric path is increasing in speed? I know I can determine if the x and y are accelerating, but I can I determine if the particle itself is increasing?
What if it was accelearating in the x direction but decelerating in the y? Would the particle's speed be increasing or decreasing?
The 'speed' is sqrt((dx/dt)^2+(dy/dt)^2), isn't it? Just look at whether that quantity is increasing or decreasing.
