nb89
- 37
I have a P-V trace for a wide open throttle and a part load. Is it possible to calculate the BMEP from these graphs?
xxChrisxx said:Integrating real curves is a *****, either find a program that can make approximate curves from a set of data points or break out the graph paper.
Actually, if you used the average pressure between two datapoints then you used the trapezoid rule! :)xxChrisxx said:Those are two marvellous suggestions. I feel especially silly about the numerical integration in excel as that is probably the easiest way to do it, I should have known that but never even thought to use the trapezoid rule. :(
