How to calculate center of gravity? emergency
The discussion focuses on calculating the center of gravity for a steel pole composed of two sections, each 40 feet long, with weights of 3,438.004 lbs and 1,283.194 lbs, respectively. The total length of the pole is 78 feet, with a 2-foot overlap between the sections. Additionally, a base plate weighing 367 lbs is included in the calculation. To determine the center of gravity, the weight distribution should be assessed by calculating the weight per foot and identifying the point at which half the total weight is reached.
  • Understanding of basic physics principles related to center of gravity
  • Familiarity with weight distribution calculations
  • Knowledge of structural engineering concepts
  • Experience with crane operation and load management
  • Research methods for calculating center of gravity for composite structures
  • Learn about weight distribution analysis in structural engineering
  • Study crane load calculations and safety protocols
  • Explore software tools for structural analysis and weight distribution
Structural engineers, crane operators, emergency response teams, and anyone involved in heavy lifting and load management in construction or emergency scenarios.
tripflex
Sorry if this is posted in the wrong section
I'm trying to find out what would be a good pick point on a steel point instead of just winging it.
There are two sections to the steel pole, both combined together to create a total of 78 feet.
The first section is 40' and weighs 3,438.004 LBS
The second section is 40' and weighs 1,283.194 LBS
The second second is slipped over the first section a distance of 2 feet to obtain that 78' distance.
I'm trying to figure out what would be the "center of gravity" on this pole in order to pick it up with a crane.
There is a base plate at the end of the pole (to connect it to another pole) that weighs about 367 lbs, the OD by the base plate is 19", the OD at the end of the pole for section one is 13.4".
The second section slips over the first section 2 feet to create the slip joint, the OD of the pole that slides over section 1 is 14.2" and the end of the pole is 8.58"
I'm just trying to put something together to get an idea of where it should be at, we have an emergency and have to take this pole down tonight, so any help or suggestions are greatly appreciated.
Thank you!
Mathematics news on Phys.org
sorry, next time we need more lead time.
hhhmmm...as a first guess...I would have calculated the weight on a per foot basis for both section...and then simply start counting pounds from one end until you get half the total weight...
  • · Replies 23 ·
11K
