How to calculate critical speed in circular motion?
The discussion centers on the calculation of critical speed in circular motion, highlighting discrepancies between two textbooks regarding the formulas: v = √(g*r) and v = √(2*g*r). The first formula is considered correct for scenarios where the normal force is zero, while the second may apply to different conditions or be incorrect. The conversation emphasizes the importance of clearly defining variables like weight and normal force when discussing these equations. A practical example involving a rock in a bucket is presented to illustrate the application of Newton's second law in determining minimum speed for maintaining contact. The critical speed is ultimately linked to ensuring the rock remains in contact with the bucket throughout its circular path.
jayadds
In one textbook, it says that the critical speed is the minimum speed at which an object can complete the circular motion. It gives the formula:
v = square root of (g*r)
However, in another textbook it says that the formula is:
v = square root of (2*g*r)
How can there be two different types of equation for critical speed? Which one is correct?
It's funny because they both start off with the same Newton's second law: w+n = mv^2/r
For the first equation, they said that critical speed occurs when n = 0 whereas for the second equation, they said that critical speed occurs when n = w. Which one is correct?
I assume we're discussing motion in a circle in a vertical plane.
For future reference, it helps to specify what all your variables are. We can't see the textbook, so have to guess what w and n are.
The centripetal acceleration needed is v^2/r.
For the string to remain tense (is this your 'n'?), gravity must be less than this: g < v^2/r.
The critical speed is therefore sqrt(g*r).
The second textbook might be discussing a different scenario. Or it might simply be wrong.
Hi, just let me put it in a better way. How would you solve this question?
You hold a bucket in one hand. In the bucket is a 500 g rock. You swing the bucket so that the rock moves in a vertical circle 2.2 m in diameter. What is the minimum speed the rock must have at the top of the circle if it is to always stay in contact with the bottom of the bucket?
Btw, is this minimum speed regarded as its "critical speed"?
In this example, I know that you would start off with Newton's second law:
N + w = mv^2/r (where N = contact force, w = weight, m = mass, v = velocity and r = radius)
To find the minimum speed, what would be the next step from there?
What do you think N will be if it loses contact? If it stays in contact?
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 19 ·
