How to Calculate $\int_0 ^{\infty} \sin t^2$ Using Complex Analysis?
  • Context: MHB
  • Thread starter Thread starter Jakob1
    Integral Sine
The discussion revolves around calculating the integral $\int_0^{\infty} \sin t^2$ using complex analysis techniques. Participants explore various methods, including contour integration and transformations of the exponential function, while addressing challenges in relating these to the sine function.
  • One participant expresses difficulty in transforming $e^{-z^2}$ to obtain $\sin t^2$ and $\cos t^2$, questioning the relationship between these functions and the exponential form.
  • Another participant notes that $e^{-iz^2} = \cos(z^2) - i\sin(z^2)$, suggesting a potential pathway for evaluation.
  • Several participants discuss the parametrization of the contour integral, with different approaches to defining the segments of the contour and the corresponding integrals.
  • There is a proposal to evaluate the integral along a triangular contour, with some participants questioning the correctness of the parametrization used.
  • Participants explore the implications of the analyticity of the function and the requirement that the integral along the closed path must equal zero.
  • One participant suggests using L'Hospital's rule to evaluate the limit of an integral as $r$ approaches infinity, while others discuss the need to estimate certain integrals.
  • There is a suggestion to consider different contours, such as a semicircle, for potentially simplifying the evaluation.
  • Finally, participants discuss the relationships between the integrals of sine and cosine functions and their connection to the original integral of interest.
Participants do not reach a consensus on the best method to evaluate the integral. Multiple competing views and approaches are presented, with ongoing questions about the correctness of certain steps and the effectiveness of different contour choices.
Participants highlight limitations in their approaches, including potential errors in parametrization and the need for careful consideration of limits and transformations. The discussion reflects a complex interplay of mathematical reasoning without definitive resolutions.
This discussion may be useful for those interested in complex analysis, contour integration, and the evaluation of integrals involving oscillatory functions, particularly in the context of mathematical physics.
Jakob1
Hello.
I'm having trouble calculating $\int_0 ^{\infty} \sin t^2$ using the fact that $\int _{\partial Tr} e^{-z^2} dz = 0$, where $Tr = conv (\{ 0, r, r + ir \})$ (a triangle).
I'm aware that I need to somehow transform $e^{-z^2}$ to get $\sin t^2, \ \cos t^2$ but I don't know how to do that.
It doesn't help if I write $e^z = e^x (\cos y + i \sin y)$, because then $e^{-z^2} = e^{y^2 - x^2} (\cos 2xy - i \sin 2xy)$, so there's no way I can get a square of $t$ that way.
How can one relate $e^z$ to $\sin t, \ \sin t^2$ differently from what is written above? I also don't see how I can use the triangle to compute this integral.
Could you help me with that?
$$e^{-iz^2} = \cos(z^2)-i\sin(z^2)$$
On the interval $[0,r]$ we have
$$\int^r_0 e^{-iz^2} \,dz = \int^r_0 e^{-it^2}\,dt = \int^r_0 \cos(t^2)\,dt-i\int^r_0 \sin(t^2)\,dt$$
Thank you.
So I know that on the intervals $[0,r]$ the integrals $$\int^r_0 e^{-iz^2} \,dz = \int^r_0 e^{-it^2}\,dt = \int^r_0 \cos(t^2)\,dt-i\int^r_0 \sin(t^2)\,dt$$ are equal.
But on this interval $[r, r+ir]$ we have $z= (r + ir)y$ so $dz=(1+i)dy$ and $z^2 = (ry+iry)^2$, so here we get:
$$ \int ^{r+ir}_r e^{-(ry+iry)^2}idy$$. This doesn't seem to be easy to compute or transform into $\sin, \ \cos$...
we also have that $$\int^{r+ir}_r e^{-iz^2} \,dz = \int^{r+ir}_r \cos z^2 dz+ i \int^{r+ir}_r \sin z^2 dz$$
Jakob said:
Thank you.
But on this interval $[r, r+ir]$ we have $z= r + iry$ so $dz=idy$ and $z^2 = (r+iy)^2$, so here we get:
$$ \int ^{r+ir}_r e^{-(r+iry)^2}idy$$. This doesn't seem to be easy to compute or transform into $\sin, \ \cos$...
Sorry , I just realized that in your question we have to use the function $f(z) = e^{-z^2}$.
So have you done the parametrizations ? what do you get ?
If we go this way: $$0 \rightarrow r \rightarrow r+ir$$
we get:
for the segment $$[0, \ r] : \ z=x$$, so $dz = dx$ and $z^2 = x^2$
$$ [r, \ r+ir] : \ z= r + iry$$, so $dz=idy$ and $z^2 = (r+iry)^2$.
So the integral has this form: $$\int_0^r e^{-x^2} dx + i \int_r^{r+ir} e^{-(r+iry)^2} dy$$.
I don't know what to do next. Could you help?
we get:
You have done the parametrization the wrong way. It should be $z = (1+i)y$ . The integral then becomes
$$ (1+i) \int_0^{r} e^{-((1+i)y)^2} dy$$
I see.
You've determined the equation of the line on which lie $$0$$ and $$r+ir$$.However, I still do not see how to use it to derive $ \sin t^2$ from this integral(s).
Sine the function $f$ is analytic the integral along the closed path (triangle) must be zero.
$$\int^r_0 e^{-(1+i)^2y^2}\,dy = \int^r_0 e^{-2iy^2}\,dy$$
which is more or less the integral we want to evaluate. It remains to find the integral along the vertical line of the triangle. You need to re-evaluate it because you have done it wrong.
I've noticed my mistake and I've just edited my post. Could you tell me if it is all right now?
On this interval $[r, r+ir]$ we have $z= (r + ir)y$ so $dz=(1+i)dy$ and $z^2 = (ry+iry)^2$, so here we get:
$$ \int ^{r+ir}_r e^{-(ry+iry)^2}idy = \int ^{r+ir}_r e^{-2r^2y^2} i dy$$Could we use this $$e^{-iz^2} = \cos(z^2)-i\sin(z^2)$$ now?
To make sure that you are doing it the right way substitute the limits of integration. You used the lower limit as $r$ but when you substitue in $z=(r+ir)y$ you get $z=(r+ir)r$ which is not the starting point of the vertical line. The same goes for the upper limit.
I'm sorry for the confusion. Let me try one more time.
The equation of the line passing through $r$ and $r+ir$ is $x=r$, so $z=r+iy$, (because $ z=x+iy$), so $dz=idy$ and $ z^2 = (r+iy)^2=r^2-y^2+2iry$, so the integral over the vertical segment is $$\int_0^r (e^{y^2-r^2-2iry})dy$$.
Is it correct this time?
Yes , you just forgot the i from differentiation. Now , you need to prove that this integral vanishes as $r \to \infty$.
$$\int_0^r e^{y^2-r^2-2iry} dy = e^{-r^2} \int_0^r e^{y^2-2iry} dy $$
I thought I could estimate it somehow or use the error function (this integral is equal to $$\frac{\pi}{2}(erf(x)+erf(1+i)r)$$), but I haven't come up with anything so far.
Hint 1: get rid of the exponential containing $i$.
Hint 2: use L'Hospital rule.
Would this question be easier to do over a different contour? Like a circle for example?
Do you mean a semi-circle ?
I know that it can also be found using a sector (Fresnel integral) but the idea is the same.
Should I use de l'Hospital's rule to the function I'm integrating? If so, I get $$\frac{-2re^{y^2-r^2}}{-2( \sin 2yr - i \cos 2yr)}$$. Did I misunderstand you?
What about $\sin t^2$?
First you need to use the property $|e^{ix}|\leq 1$ , then apply the differentiation.
I need to prove that this integral $$\int_{0}^{r} \frac{e^{y^2 - r^2}}{e^{2ir}}\,d y$$ vanishes as $r$ approaches infinity.
$$| e^{y^2 - r^2}e^{-2ir} | \le | e^{y^2-r^2} | $$, because $$|e^{-2ir}| \le 1$$.
But now I don't see how I can apply the de l"Hospital rule, because there is no denominator.
Good. Now you get
$$| \int^r_0 e^{y^2 - r^2}e^{-2ir} \, dy | \le \frac{\int^r_0 e^{y^2}\,dy}{e^{r^2}}$$
$$\lim_{r \to \infty} \frac{\int^r_0 e^{y^2}\,dy}{e^{r^2}} = \lim_{r \to \infty}\frac{e^{r^2}}{2r e^{r^2}} \to 0$$
Ok, I see that now.
Now there remain only two integrals:
$$\int_0^{\infty} e^{-x^2} dx = (1+i) \int_{0}^{\infty} e^{-2iy^2} \,d y = (1+i) \int_{0}^{\infty} (\cos 2y^2 - i \sin 2y^2) \,d y$$.
$$= \int_{0}^{\infty} \cos 2x^2 \,d x - i \int_{0}^{\infty} \sin 2x^2 \,d x +i \int_{0}^{\infty} \cos 2x^2 \,d x + \int_{0}^{\infty} \sin 2x^2 \,d x$$
So $$\int_{0}^{\infty} \cos 2x^2 \,d x - \int_{0}^{\infty} \sin 2x^2 \,d x =0$$
and $$\int_{0}^{\infty} \cos 2x^2 \,d x + \int_{0}^{\infty} \sin 2x^2 \,d x = \int_0^{\infty} e^{-x^2} dx $$.
Is that correct?
If it is, then $$\int_{0}^{\infty} \cos 2x^2 \,d x = \int_{0}^{\infty} \sin 2x^2 \,d x = \frac{1}{2} \int_0^{\infty} e^{-x^2} dx $$
Ok, I checked my result on wolfram :)
Thank you very, very much for all your help!
very nice. I hope every think is clear , now.
  • · Replies 29 ·
