How to calculate pressure due to fan
  • Thread starter Thread starter red4life
    Fan Pressure
The discussion revolves around calculating the pressure required by a fan to circulate air through an underground horizontal pipe, specifically in the context of simulating Earth tubes for pre-cooling using EnergyPlus software. Participants explore various factors influencing pressure calculations, including friction losses and system characteristics.
  • One participant seeks to determine the pressure needed to pump air through a 50m long, 0.3m diameter pipe at a velocity of 2 m/s, with a volume flow rate of 0.14m3/s.
  • Another participant questions how the air exits the pipe and suggests using an online duct calculator to assess friction and potential losses at the entrance or exit.
  • A participant mentions the need for a restriction curve for the Earth tube and clarifies their understanding of it in relation to a system curve.
  • Concerns are raised about the low pressure drop calculated (8.8 Pa) based solely on frictional losses, prompting questions about whether additional factors should be considered.
  • One participant provides a formula for calculating fan input power, emphasizing the need to find the pressure drop in Pascals to determine the manometric head.
  • Another participant suggests looking at fan catalog data as an alternative approach to understanding the pressure requirements.
Participants express varying levels of understanding regarding the concepts of restriction curves and pressure calculations. There is no consensus on the best method to calculate the required pressure, and multiple viewpoints on the factors influencing pressure losses remain present.
Participants mention specific parameters such as friction coefficients and head loss but do not reach a definitive conclusion on how these affect the overall pressure calculation. The discussion also highlights the potential for additional losses that may not have been accounted for in initial calculations.
red4life
Hello everyone,
I am trying to simulate Earth tubes for pre-cooling using the EnergyPlus software. Basically a fan will be used to circulate ambient air through an underground horizontal pipe.
The software requires an input field of "Fan Pressure Rise" which I am guessing is the pressure that is created by the fan to force air through the pipe.
My question is, how can I calculate the pressure that needs to be generated to make the air flow through the pipe?
System specs are:
pipe length = 50m
diameter (internal) = 0.3m
velocity = 2 m/s
volume flow rate = 0.14m^3/s
Thanks.
Welcome to PF!
How does the air get out of the pipe?
You can use an online duct calculator to calculate the friction in your duct (not much), but if there are any losses at the entrance or exit, you'll have to add those to it.
russ_watters said:
Welcome to PF!
Thanks for the welcome!
Basically the Earth tube has an inlet and outlet. A fan draws ambient air at the inlet and pumps the air through the tube. The air at outlet will be fed into an HVAC system.
What I need to know is, how can I determine the pressure that needs to be created in order to pump the air along the length of the tube.
Do you have a restriction curve for your 'earth tube'?
I'm sorry I don't understand what a restriction curve is. Is this the same as a system curve? If yes, then no I don't have one.
I shall point out that the tubes will be buried 3m deep. The friction coefficient is 0.022 and head loss is 0.75m (just taking the horizontal section of pipe i.e. no minor loss).
Where do I go on from here?
Well if unrestricted, there is virtually no pressure loss at the volume you are talking about.
Did you look at one of the duct calculators I linked?
Ok people, for instance I want to calculate the fan input power (assuming efficiency of 0.5). I will use the equation:
Fan input power = (volume flow rate X pressure) / fan efficiency
How do I calculate the "pressure" in that equation? If I simply use the friction (major) loss formula, I get a pressure drop of 8.8 Pa resulting in a input power of only 2.46 W which seems really low.
Any thoughts? perhaps I need to calculate something more for the "pressure" instead of only frictional (major) losses?
I dint see any links in your reply. Can you recommend me one?
Well since the full expression is
input power (W) = Q (m3/s) x air density (kg/m3) x g (m/s2) x manometric head (m)/ fan efficiency
so if you find the pressure drop in Pa, you can divide it by the specific weight of air under those conditions ie pressure drop/(g x air density), to get your manometric head.
Hope this helps
  • · Replies 31 ·
