How to Calculate the Index of Refraction of Acetone?
  • Thread starter Thread starter kevinf
    Light Refraction
The index of refraction of acetone can be calculated using Snell's Law, which states that sin(theta1) / sin(theta2) = n2 / n1. In this case, the angle of incidence (theta1) is 30 degrees, and the angle of refraction (theta2) is 42 degrees. By substituting the refractive index of air (n1 = 1) into the equation, the calculation yields an index of refraction for acetone (n2) of approximately 1.34.
  • Understanding of Snell's Law
  • Basic trigonometry (sine function)
  • Knowledge of refractive indices
  • Familiarity with light refraction concepts
  • Research the application of Snell's Law in different mediums
  • Learn about the refractive index of various substances
  • Explore the relationship between angle of incidence and angle of refraction
  • Investigate the speed of light in different materials
Students studying optics, physics educators, and anyone interested in the properties of light and refraction in various materials.
kevinf
A pair of students measure the refraction of light in passing from acetone into air for several angles. When the angle of incidence is 30, the angle of refraction is 42.
(a) What is the index of refraction n of the acetone?
n=c/v
i am not sure if there is another way to calculate the index of refraction. i can't find v (speed of light in acetone) so i don't think the provided equation will work. is there another way to calculate it? i also searched up google for index of refraction for acetone and it gave me 1.36 but even that's not correct. any ideas?
You will find your answer by googling Snells law
ok so snelll's law says sim(theta1) /sin(theta2) = n2/n1. wouldn't i still need to know the index of refraction for air? or is that a constant that is usually given?
You will find your answer by googling index of refraction for air.
The refractive index of vacuum is 1 and the refractive index of air is slightly higher,the difference,however, is so very small that we take the refractive index of air as being 1.
so just to make sure it would be sin(30)/sin(42) = n2/1? i just want to make sure since this is my last try
sin42/sin30.This gives the refractive index of acetone from air.
so sin(42)/sin(30) = n2/1? so it should be about 1.34 right?
Yes.:biggrin:
  • · Replies 25 ·
