How to calculate the potential energy of a spring?
The discussion revolves around calculating the potential energy of a spring system, particularly in relation to a mass and its motion influenced by gravitational and spring forces. Participants are attempting to derive an equation for potential energy as a function of displacement.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants are exploring the relationship between gravitational potential energy and the potential energy stored in the springs. There are attempts to formulate equations that incorporate both types of energy, with some questioning the validity of their approaches and the role of velocity in the equations.
There is ongoing dialogue about the correct formulation of the potential energy equation, with some participants providing guidance on how to consider the contributions from both gravitational and spring forces. Multiple interpretations of the problem are being explored, particularly regarding the components of forces and energy.
Some participants express uncertainty about the assumptions made regarding the system, such as the effects of the springs and the nature of the forces involved. There is also mention of the need for a free body diagram to clarify the forces acting on the mass.
  • #31
haruspex said:
No, that's your job.
To recap:
In post #16 you had the right expression for the potential energy in the springs.
Unless you have some good reason to suppose it is in the vertical plane, go with Sammy's suggestion that is is horizontal, so discard any gravitational term.
In post #21 your force equation is quite wrong. You cannot add forces acting in different directions as though they are scalars. If you want the net force from the springs then you need to consider the x and y components of the forces. (This is the path berkeman was going down, but he wrongly tried to apply that to the PE of the springs instead of to their tensions.). But I don't think you need to worry about forces anyway, just concentrate on energy.
In post #21, your KE expression had two copies of 1/2 mv2. There is one mass m moving at speed v, not two.
From all that, see if you can put together the correct expression for the total energy.
the kinetic energy in function of x is : KE(x)= 1/2*m*v^2= 1/2*m*(dx/dt)^2
Is it correct now?
  • #32
Is it correct now?
Yes. So what is the total energy?
  • #33
total energi = 1/2*m*(dx/dt)^2 + mgx +1/2*k*(x/sin(a) - L)^2 + 1/2*k*(x/sin(a) - L)^2
the kinetic energy is 1/2*m*(dx/dt)^2 ... Can we rewrite the kinetic energy equation in function of x instead of dx ?
  • #34
No, you cannot express it purely in terms of x except by solving the differential equation.
What is the whole question? You originally said you wanted to find the potential energy, which you have done. Why is the KE of interest? Do you need to find the equation of motion?
Also, I see you have reintroduced mgx. That is applicable if the motion is in the vertical plane, but not if it is in the horizontal plane. Do you know which plane it is in? If the question does not state, I would assume it is horizontal, and throw away the mgx term.
  • #35
Why horizontal though?
The forces in the horizontal direction cancel each other ( If we assume that both of the springs have a constant of k) and the net force in the y direction. So It will only move vertically...?
  • #36
Horizontal plane. That is, the diagram may be as viewed from above.
  • #37
I have to find KE , it is required ..
I do want to find the equation of motion in terms of x for KE and PE and the force on the brick as a function of x ..
Iam sure it is moving in vertical direction ..
  • #38
Ok, if you are sure it is vertical keep the mgx.
What type of motion do you think it will be?
  • #39
potential energy and I got it correct as you said before
  • #40
Not sure what question you are answering. I asked what kind of motion you thought would result.
  • #41
no idea
  • #42
ramialsaiad said:
no idea
In the simpler case of a mass hanging from a spring, or lying on a smooth table and connected to a horizontal spring, what type of motion occurs?
  • #43
potential energy
  • #44
ramialsaiad said:
potential energy
That is not a type of motion. Here are some types: constant velocity, constant acceleration, elliptical orbit, simple harmonic motion. Pick one.
  • #45
  • #46
Right. Can you write the generic form of the equation for that? If so, try that out as a solution to your differential equation.
  • #47
I do not know how to do ?
if you can provide the starting equation to me that will be nice ,, then I try to go further
  • #48
I find it very strange that you have been given a problem in harmonic motion yet appear to know so little about it.
The general form of the solution is ##x=A\sin(\omega t+\phi)##, where A is the amplitude, ω is the frequency and φ is the phase. Or you can use cos instead of sin, which changes the value of φ but keeps all else the same.
  • · Replies 21 ·
  • · Replies 20 ·
