How to calculate torque for a motor?
  • Thread starter Thread starter fkneg12
    Motor Torque
To calculate the required torque for a motor to lift a weight, the formula Torque (T) = Force (F) x Displacement (D) is essential. For example, lifting a 1 kg weight (1 N) with a drum diameter of 1 meter requires a minimum torque of 1 Nm. Additionally, the power equation P = 2 * π * f * T can be used, where P is power in Watts, f is frequency in Hz, and T is torque in Newton-meters. It is crucial to convert RPM to frequency for accurate calculations.
  • Understanding of basic physics concepts, particularly Newton's laws of motion
  • Familiarity with torque and its units (Newton-meters)
  • Knowledge of power calculations in mechanical systems
  • Ability to convert RPM to frequency (Hz)
  • Study the relationship between torque and power in electric motors
  • Learn how to apply Newton's equations of motion for various lifting scenarios
  • Research the impact of drum diameter on torque requirements
  • Explore the conversion methods between RPM and frequency for motor calculations
Engineers, mechanical designers, and hobbyists involved in motor selection and torque calculations for lifting applications.
fkneg12
Hi all,
Just wondering how to work out what torque motor we need to get to lift a certain (as yet undetermined) weight.
Is there a formula to work out what torque we need once we know the weight?
Thanks in advance
It depends on the diameter of the drum that you are winding your cable onto. If you had a weight of 1 Kg (1 N) and a dia of 1 meter youd need a minimum torque of 1NM.
Torque is Force X Displacement. So you could calculate your force using Newtons equations of motion to get your missing variable like velocity if needed. Or you could just assume a height and multiply by gravity. that will give you force. This however is also assuming a 0 angle in the lift.
If you want to calculate torque which occurs in shafts, you have to use this formula;
P=2* (pi) * f *T
T is torque (Newton*meter)
P is power (Watt)
pi = 3,1415...
f is frequency of rotation (1/s = Hz)
sometimes you can find revolution as rpm. So you have to change rpm to frequency.
(1 Hz = 60 rpm)
:smile:
  • · Replies 22 ·
  • · Replies 17 ·
