How to Calculate Volume of a Rotated Graph Using the Shell Method?
  • Thread starter Thread starter tbone413
    Graph Volume
The problem involves calculating the volume of a solid formed by rotating the area bounded by the curves x = 1, y = x^2, and y = 0 around the x-axis, with a focus on using the shell method.
  • Participants discuss the shell method and its applicability, with some suggesting alternative methods for finding the volume. There is a focus on identifying points of intersection and determining boundaries for integration.
Participants are exploring different methods for solving the problem, including the shell method and a direct integration approach. Some guidance has been offered regarding the boundaries and the setup of the integral, but there is no explicit consensus on the method to use.
There is mention of confusion regarding the shell method and its requirements, as well as the need to find points of intersection between the curves. The discussion reflects uncertainty about the correct approach to take given the problem constraints.
tbone413
Find the volume of the solid found by rotating the area bound between
the curves x = 1, y = x^2, y = 0, around x-axis.
I know you have to solve this using the shell method, but I just get extremely confused while trying to do it. Maybe someone could explain it to me?
This is the formula for the cylindrical shell method:
[tex]\int_a^b2\pi xf(x)dx[/tex]
you can also use [tex]\int_a^bA(x)dx[/tex]
The second one would be easier.
Sorry! I was mistaken when I said the area was unbounded. The first thing you need to do is find where these curves intersect and determine the leftmost and rightmost boundaries of X.
Normally to find points of intersection you would set the two curves you wish to find the x values that satisythis equation. However they are much more easily found in this particular problem by drawing a quick sketch. It comes out at x=0 to x=1
Also, this does not require shell method at all. Shell method is for when you cannot create an infinite number of lines between between your boundaries that is perpundicular to your axis of revolution such that one of those lines would hit the same curve twice. In this case all you need to is:
[tex]\pi\int_0^1\ (x^2)dx[/tex]
Should be (f(x))^2.
Would that end up being...
[tex]\int^{1}_{0}(\pi r^2)dx[/tex]
where r = "Outer radius" (1) minus "inner radius" ([tex]x^2[/tex])
(I hope so, I have a test tomorrow)
No, because x = 1 is the vertical boundary in your integration sign.
Ok...I think I get it.
[tex]\int^{1}_{0}\pi (x^2)^2 dx[/tex]
= [tex]\pi*\int^{1}_{0}x^4 dx[/tex]
= [tex]\pi*(1^5/5-0)[/tex]
= [tex]\pi/5[/tex]
Is that right?
Looks right.
I should've said x = 1 is the vertical line that limits how far horizontally you should integrate.
