How to calculate work from force applied at downward angle and friction
The discussion focuses on calculating the work done on a box when a force of 175 N is applied at a downward angle of 35 degrees, with friction considered. The box has a mass of 125 kg and a coefficient of kinetic friction (uk) of 0.25. The calculations reveal that the normal force is 1326.63 N, and the frictional force is 331.65 N, leading to a net force of -188.30 N. Consequently, the work done is calculated as -2,824.5 Joules, indicating that the box does not move due to the frictional force exceeding the applied horizontal force.
  • Understanding of Newton's laws of motion
  • Knowledge of free body diagrams
  • Familiarity with work-energy principles
  • Basic grasp of friction and normal force calculations
  • Study the concept of net force and its implications on motion
  • Learn about the work-energy theorem in physics
  • Explore different angles of force application and their effects on work done
  • Investigate the relationship between friction coefficients and motion outcomes
Students studying physics, particularly those focusing on mechanics, as well as educators looking for practical examples of force and work calculations.
Chris Mexas
If you exert a force of 175 N at a downward angle of 35 degrees on a box with a total mass of 125kg for a distance of 15m, and the box and the floor have a uk of 0.25, what is the work done?
F= (m)(a)
Fk= (uk) (Fn)
W = (F)(d)
1) First I drew a free body diagram: the first horizontal vector will be in the positive direction and will be F=(175)(cos 35) = 143.35 N.
2) I drew a vertical vector in the negative (down) direction, representing the weight of the box F=(125)(9.81) = 1,226.25 N.
3) Since the box is being pushed at an angle, I drew the vertical component of the force, which is also negative (down) F=(175)(sin 35) = 100.38 N.
4) The normal force Fn should be equal to (and in opposite direction to) the two vertical forces calculated in steps 2 and 3. Fn=(1,226.25 + 100.38) = 1326.63 N.
5) The Force due to friction would then be shown as a vector in the negative direction and would be Fk = uk (FN) = (0.25)(1326.63) = 331.65 N.
Since the force caused by friction is larger than the horizontal force applied to the box, (assuming I did everything right), does this mean that the box is not moving?
The net force would be F=-331.65 + 143.35 = -188.30N
If I apply this to the equation for work I would get W = (-188.30)(15) = -2,824.5 Joules
Is this correct?
Thanks for your help!
Chris
fizzsucks,
The only thing that could be wrong with steps 1 and 3 is my interpretation of downward angle. I'm assuming that a downward angle of 35 degrees means that the force is applied at an angle of 35 degrees with respect to the horizontal axis. In other words, an angle of 0 degrees would be horizontal, an angle of 90 degrees would be vertical. I could try the problem using the same formulas but applying 55 degrees (90-35) instead of applying 35. Is this what you mean?
  • · Replies 41 ·
