How to convert boric acid to boric oxide
  • Thread starter Thread starter lmenwe
    Acid Convert
To convert boric acid to boric oxide, a method involving the addition of methanol and concentrated sulfuric acid to boric acid crystals is suggested, followed by heating and igniting the evolved vapors. The volatility of the product is crucial to this conversion process. The presence of metals like barium and copper can interfere with the test, which requires further exploration to understand the underlying reasons. It is noted that roasting boric acid is another method for achieving this conversion. The discussion emphasizes the importance of understanding the chemical interactions at play in the conversion process.
lmenwe
How to convert boric acid to boric oxide?
To a few crystals of boric acid in a test-tube add a little methanol and some concentrated sulphuric acid. Heat and ignite the vapour evolved. Why should barium and copper interfere in this test?
Well, what do you think? You need to show your thoughts/ideas on this question, before you get help.
i really want to know how..
Wow, there are a lot of views on this and only one response!
Why do you think that methanol and sulfuric acid were added? The product is volatile (it evaporates). This volatility is key to the method.
Is this any help?
What is this question about? IIRC to convert boric acid to boric oxide you should roast it. Procedure listed is a test for boric acid presence.
Yes, but the method he is following involves reacting it with methanol and sulfuric acid followed by ignition. His method won't work is metals like copper or barium are present and he needs to figure out why...
9K
  • · Replies 19 ·
  • · Replies 20 ·
