How to correctly calculate this integral using u substitution?
  • Thread starter ana111790
    Integral
4 replies · 8K views · last reply
ana111790
Calculate the following:
[PLAIN]http://img852.imageshack.us/img852/5580/integraltocalculate.jpg
u substitution where: u= (1-r/R); du = -1/R dr
= umax*INT(-R*u1/7 du)
= -umax*R*(7/8)u8/7 evaluated over 0,R
= -(7/8)*R*umax [(1- R/R)8/7 - (1- 0/R)8/7]
* equals 0
**equals 1
= (7/8)*R*umax
The answer at the end of the book says it should come out to be (49/60)*Umax (no R in the term)
Can anyone help me understand what I am doing wrong?
Did you copy the problem correctly?
What you have looks fine.
Is this the complete problem, as stated?
The integration is actually part of the following fluid mechanics problem:
Water flows steadily through the round pipe in the figure. The entrance velocity is Uo. The exit velocity approximates turbulent flow, u = umax(1 − r/R)1/7. Determine the ratio
Uo/umax for this incompressible flow.
[PLAIN]http://img200.imageshack.us/img200/5879/fluidsproblem.jpg
Conservation of mass
Qin=Qout
Vo*Ain = Aout * INT(V(r) dr)
U0*pi*r2 = pi * r2* INT(umax*(1- r/R)1/7dr)
which is where the integration I wrote earlier comes in.
The final answer should be U0/umax = 49/60 but with my calculations I get U0/umax = 7R/8.
[tex]u(r)=u_{max}\left(1-\frac{r}{R}\right)^{1/7}[/tex] is the velocity of the fluid at distance, r, from the center of a pipe with circular cross-section. This makes sense, because the fluid at the center flows fastest, u(r) = uMAX, and flow is slowest near the pipe surface: r → R, u(r) → 0.
The fluid is incompressible, so for an input flow velocity, u0, the input flow rate, u0·AIN, is equal to the flow rate in the pipe and equal to the exit flow rate. To get the flow rate in the pipe and thus the exit flow rate, integrate u(r) over the cross-sectional area of the pipe.
[tex]u_0\cdot A_{in}=\int_0^Ru_{max}\left(1-\frac{r}{R}\right)^{1/7}{2\pi r}\,dr\ ,[/tex] where AIN = πR2.
See if this gets your desired answer.
It should.
To integrate, use the substitution, [tex]t=1-\frac{r}{R}\[/tex] then [tex]r=R(1-t)\,.[/tex]
I got the right answer now. Thank you so much for your help!
