How to Create a Pyramid in C++?
  • Topic: C/C++
  • Thread starter Thread starter jacy
    C++ Pyramid
7 replies · 64K views · last reply
jacy
Hello,
I am trying to print an equilateral triangle, made up of * (stars), of height 8. Can someone please give me some hint. I am not getting the desired output. Thank you. Here is my code.
Code:
#include<iostream.h>
#include<iomanip.h>
void main()
  int n=8;
	 for (int row=1; row<=8; row++)
		  for (int col=0; col<row; col++)
				cout<<setw(n=n-1)<< '*';
		  cout << endl;  // end the line.
ew c++ io commands, can't remmeber what the setw command does so it may be best for you to post the errored output you got
...and just printing stars you won't get a real equilateral triangle so I'm guessing your looking for 8 stars each edge.
also are you filling the triangle?
and you can use n-- rather then n=n-1...doesn'treallly matter but n-- looks nicer.
my best guess though is your forgetting to print spaces.
jacy said:
Hello,
Please show us exactly what this triangle is supposed to look like, by literally typing it out inside a (code)(/code) block. (square brackets instead of parentheses, of course).
Code:
main()
  int n=8;
	 cout<<"45,90,45 degree triangle"<<endl;
	 for (int y=1; y<=8; y++)
		for(int space=8-y; space>0; space--)
			cout<<" ";
		for (int x=0; x<y; x++)
			cout<<"**";
	cout<<endl<<"circle"<<endl;
	for (double y=-10; y<=10; y++)
		for (double x=-10; x<=10; x++)
			if(x*x+y*y<=100)
				cout<<"*";
			else
				cout<<" ";
	cout<<endl<<"Equilateral Triangle"<<endl;
	for (double y=7*sqrt(3); y>=0; y--)
		for (double x=-7; x<=7; x++)
		if(x==0)
			cout<<"*";
		else if(x<0&&y/(x+7)<=sqrt(3))
			cout<<"*";
		else if(x>0&&y/(7-x)<=sqrt(3))
			cout<<"*";
		else
			cout<<" ";
	system("PAUSE");
Please don't do people's homework for them.
something wrong
when i tried to run the programm it had some problems.this is how i change it but it works
#include <cmath>//the first change
int main()
int n=8;
count<<"45,90,45 degree triangle"<<endl;
count<<" ";
count<<"**";
count << endl; // end the line.
count<<endl<<"circle"<<endl;
for ( y=-10; y<=10; y++)//second change
if(x*x+y*y<=100)
count<<"*";
else
count<<" ";
count<<endl<<"Equilateral Triangle"<<endl;
for (y=7*sqrt(3); y>=0; y--)//third change
if(x==0)
count<<"*";
count<<"*";
count<<"*";
else
count<<" ";
return 0;//fourth change
