How to derive Schrodinger's equation?
9 replies · 4K views
Astrocyte
Homework Statement:: Derive Schrödinger equation
Relevant Equations:: Schrödinger Equation
I want to find the derivation of Schrödinger Equation.
Actually, I learned quantum mechanics already, but I think the proof that begins from the plane wave solution is quit ambiguous.
Because I feel that the derivation of physical equations from "the solution" is not a right approach.
Is there any more elegant derivation that starts from the fundamental principle like conservation of energy and constraint condition?
That's not really how physics work as it is an empirical science. You can typically start from the Schrödinger equation, which (on the more general form) will give you quantum mechanics. Then you can go out and do experiments to verify the predictions of quantum mechanics.
The way you arrive at things is typically educated guesswork rather than derivations from first principles. In some sense, the Schrödinger equation can be taken as the first principle.
Now, that being said, there are other equivalent formulations of quantum mechanics that rely upon other first principles where you can start from those and derive the Schrödinger equation. However, by the nature of equivalence, you could also have done it the other way around. (Cf. Newtonian mechanics vs Lagrange mechanics.)
Reply
If I remember correctly one can derive the the Schrödinger equation from the path integral formalism starting from the classical Lagrangian ##L = \frac{m}{2}\dot{x}^2- V(x)##.
Reply
Richard Feynman (in “Feynman lectures Vol. III”, Chapter 16) puts it in the following way:
Where did we get that [Schrödinger’s equation] from? Nowhere. It’s not possible to derive it from anything you know. It came out of the mind of Schrödinger, invented in his struggle to find an understanding of the experimental observations of the real world. You can perhaps get some clue of why it should be that way by thinking of our derivation of Eq. (16.12) which came from looking at the propagation of an electron in a crystal.
Reply
Thank you for the answer.
The elements of Schrödinger equation are quit familiar one to me. The equation includes hamiltonian and energy.
So, I thought it can be derived from Lagrange mechanics(or Hamilton mechanics), which has basic principle called "principle of least action", or Lagrange multiplier (that is used to derive canonical ensemble). But I could not find it.
As you said, It maybe become the first principle of quantum mechanics like Newton's second law in classical physics. Then, the plane wave solution could be an example of the first principle like free fall motion in Newton mechanics.
I don't think it is what you are looking for, but back in the day, I liked this discussion
from Borowitz Fundamentals of Quantum Mechanics (1967)
Reply
Richard Feynman's doctoral thesis is exactly such a derivation. Not bad for a human. I'm not sure he extracts Sschrodinger per se.
Reply
Before Schrödinger there was de Broglie, who had the idea that a wave of the form ##\psi(x,t) = e^{i kx - \omega t}## was associated with a particle. Then ##\hbar k## would be associated with the momentum of the particle, and ##\hbar \omega## would be associated with the energy. Assuming that the Newtonian relationship between momentum and energy held, so that ##p^2/2m = E##, this implies ##\hbar^2 k^2/2m = \hbar \omega##.
Clearly, ##\psi## would then satisfy ##- \frac{\hbar^2}{2m} \frac{d^2 \psi}{dx^2} = i \hbar \frac{d \psi}{dt}##. (It also satisfies ##|\dfrac{(\frac{d \psi}{dx})^2}{2m}| = |\dfrac{d\psi}{dt}|##, but that's an ugly, nonlinear equation. Nature wouldn't be so cruel...)
Reply
Reply
There is an elegant, well-motivated derivation of the Schrödinger equation in Modern Quantum Mechanics by JJ Sakurai. It is based on the expected properties of the time evolution operator.
Reply
