How to design a barrel cam to improve torque?
This discussion focuses on designing a barrel cam to enhance initial torque in mechanical systems, particularly in butterfly valve actuators. Key insights include the importance of the helical track angle, which directly influences the torque ratio. The design should feature a central curve close to vertical and end curves that are more horizontal to optimize torque. Additionally, the use of bearings and a dual-track system is recommended to minimize friction and wear during operation.
  • Understanding of cam and follower mechanisms
  • Knowledge of torque and axial force relationships
  • Familiarity with mechanical design principles
  • Basic skills in sketching and interpreting mechanical diagrams
  • Research "MACHINERY'S HANDBOOK" for detailed cam design principles
  • Explore the effects of friction in mechanical systems and potential solutions
  • Investigate the use of bearings in cam mechanisms to reduce wear
  • Learn about the mathematical modeling of torque profiles in cam designs
Mechanical engineers, designers of actuator systems, and anyone involved in optimizing torque in mechanical applications will benefit from this discussion.
Olla
Hallo
Could someone suggest me how to design a barrel cam (for example like in the butterfly valve actuator) to improve the initial torque generated by the movement ?
Welcome to PF.
The angle of the helical track on the barrel sets the torque ratio.
You need to attach a sketch of your cam and follower.
here is the sketch
the cam and follower are similar to this
If the input is h, and the output is g, then it has high initial torque now, because the ends of the track are curved to move the follower more slowly.
Slow follower movement can provide high torque, fast follower gives low torque.
Thanks for the support
The follower (green part) moves up and down and rotate , the white part is fixed.
The movement is from B to A in vertical position
Axial movement of the green shaft inside the fixed barrel causes the green shaft to rotate.
For linear axial movement, the rotation is initially slow, so it has high initial torque.
So I need to eliminate the initial and final straight path line and decrease the initial angle to become more flat ?
That depends on what you mean by "improve torque".
The relationship between axial force, and the rotational torque, is the tangent of the track angle on the surface of the cylinder. Change the direction of the track on the barrel, to change the ratio of those forces.
What I need Is the maximum torque value at the beginning and at the end of the travel
That appears to be what you have now. The ends of the track have slower movement, therefore higher torque.
ok thanks
To me it seems @Olla is asking for maximum torque on the Green part with the White part being fixed.
Since the Green part moves both horizontally and rotationally, as it is currently designed, the maximum torque on the Green part occurs as it moves laterally in the center part of the groove.
The central part of the curve should be close to vertical as shown in the sketch, and the ends of the groove should be closer to horizontal in the sketch.
In other words, those curves at the ends of the groove should bend the opposite way from the way they do now.
Cheers,
Tom
I disagree.
The torque is generated in the green follower as it is forced axially along the white barrel.
At any point in the axial travel, if it is stopped by a rotational load, the greatest torque and slowest motion will be at the ends of the curve.
The "∫" shape of the track seems to be designed to accelerate rotation at the starting end, then to decelerate rotation at the other, as the rotation and axial movements stop.
Ahh . . . Here be the rub!
Post 3 above shows both a line drawing and a 3D representation. I was referring to the line drawing and had the Green pin moving horizontally. If the Green pin is moving vertically in the line drawing, then we agree, the 3D representation is what is needed.
Cheers,
Tom
Tom.G said:
If the Green pin is moving vertically in the line drawing, then we agree, ...
We do agree.
Yes , it works in this way :-)
The setup is based on friction. Depending on the expected wear and the range of forces involved you may need to assess the friction as limiting factor too. Some bearings on the driving pin? Driving pins on two sides?
To reduce wear and make assembly possible, I would expect to machine two identical tracks in the barrel, separated by 180°, so the follower could be a pin pushed through a hole in the green push-rod, the rod that then rotates. That would remove side forces between the follower and the barrel, during operation.
We have some idea from post #3, assuming that the scale is in millimetres.
There may be space for a miniature bearing on each end of the pin.
Yes , I'm considering using bearings and the hole is specular on both side of the cylinder.
What kind of formula can I use to calculate the proper profile to check the torque value at different height ?
The track that the pin follows is specified by the angular rotation of the pin, along the length of the pin travel. That is your table of h and g. When plotted as a graph of g against h, the slope of the line is the ratio of axial linear force to rotational torque.
Details of cam design can be found in:
Industrial Press Inc.
200 Madison Avenue
New York, New York 10016-4078
My 23rd Edition (1988) has 27 pages devoted to cams and their design.
The current version is an expensive book at just under USD $200. eBay has some used earlier versions around 80% off.
If you do much mechanical stuff it is well worth the cost.
Cheers,
Tom
  • · Replies 18 ·
30K
