Somanna
- 3
No separate coolant is used, instead lubricating oil to be used for both lubrication and cooling of engine. How to calculate radiator size, coolant flow rate?
The discussion focuses on designing a radiator to dissipate heat from a 39 kW rotary engine using lubricating oil for both lubrication and cooling. Key calculations include determining radiator size and coolant flow rate based on engine efficiency, which is stated as 90%, and brake-specific fuel consumption (BSFC) of 300 g/KWH. The overall heat transfer coefficient is crucial for sizing the radiator, and references are provided for further understanding. The conversation emphasizes the complexity of custom designs compared to off-the-shelf components.
PREREQUISITESMechanical engineers, automotive designers, and anyone involved in custom engine cooling solutions will benefit from this discussion.
Efficiency of the engine is calculated as 90% and BSFC is 300 g/KWH. I am using 5W40 oil for this purpose. So that the lubrication can be more efficient even during low temperature.Nugatory said:Roughly how efficient is your engine? That will tell you how much waste heat will have to be dissipated by the radiator per unit time. Why are you designing a radiator instead of using an off-the-shelf component?
Somanna said:Efficiency of the engine is calculated as 90% and BSFC is 300 g/KWH. I am using 5W40 oil for this purpose. So that the lubrication can be more efficient even during low temperature.
What do you mean by off-the shelf-component?
Yes, its volumetric efficiency.but then its assumed value. No, I don't want a off the shelf component. I am in a situation where i need to understand the concept and apply the same in design part.SteamKing said:IC combustion engines are never 90% efficient, thermally. You are lucky if a small engine is 30% efficient. Are you sure this figure doesn't refer to the volumetric efficiency of the engine, i.e., how well air flows into it?
You can purchase this item by going into a store and picking it up off the stock shelf, i.e., it's ready made.
Somanna said:Yes, its volumetric efficiency.but then its assumed value. No, I don't want a off the shelf component. I am in a situation where i need to understand the concept and apply the same in design part.
