How to determine if a semiconductor laser is broken
To determine if a semiconductor laser is broken, users should utilize a multimeter to assess the voltage-current (V/I) characteristics and check for common faults such as static discharge damage. If the laser emits light but at a lower intensity, measuring the light intensity (LI properties) can help confirm if the laser is functioning properly. Additionally, using a spectrometer or optical spectrum analyzer (OSA) to analyze the emission spectrum can reveal whether the laser is operating in the correct lasing mode. Common issues include damage from static discharge and improper drive circuit conditions.
  • Understanding of semiconductor laser operation
  • Familiarity with multimeter usage for electrical measurements
  • Knowledge of light intensity (LI) measurement techniques
  • Experience with optical spectrum analyzers (OSAs)
  • Research methods for measuring V/I curves in semiconductor lasers
  • Learn about typical faults in semiconductor lasers and their diagnostics
  • Explore the use of spectrometers for analyzing laser emission spectra
  • Investigate protective measures against static discharge in laser handling
Laser technicians, electrical engineers, and researchers involved in semiconductor laser diagnostics and repair will benefit from this discussion.
narra
Hi,
I was wondering if someone could tell me what the best way would be to determine if a semiconductor laser is broken using a multimeter?
I have a semiconductgor laser that is still emitting but the signal appears lower than expected and it is hard to tell if it is broken internally. Does anyone know what the common problems would be?
Thanks
Science news on Phys.org
With a multimeter, you can check if the electric properties (mainly the V/I curve) are still the same. Be careful if the laser has no electronics to manage the current, in that case your measurements can break the laser.
Can you measure the laser intensity directly?
Hi, I am getting some light out and I guess measuring the LI properties would allow me to clearly see if my source is lasing or not. I was wondering though if there were some typical faults that could be used to determine quickly and with some confidence if the laser had be damaged, e.g. measuring a protection diode or something.
Do you know what the most typical faults would be?
Thanks
you are not giving us much to go on
how about a model of the laser module ( diode) ...
do have a pic of it? do you have a link to some data for it ?
playing 20 questions isn't really much fun :wink:
Dave
If you have access to a spectrometer or monochromator you can check the emission spectrum. The lasing mode(s) is/are usually very narrow, while spontaneous emission is broad.
In my personal experience the most common way to kill a laser diode is the combination of an undergrad student with static discharge. Besides that, it is hard to guess the reason without having more details.
Thanks for your comments everyone.
I am quite sure the laser is broken. I sort of already knew this as the spectrum, as seen on an OSA, is weak and not particularly sharp. The problem is that if I do this measurement I could also suspect that the drive circuit is faulty and not delivering the correct conditions for the laser to lase. Really what i was attempting to find out here was if there were common faults, generally speaking, which could occur - perhaps because of handling or excesses drive currents/ high voltages which could be easily identified through the simple use of a multimeter. Perhaps static discharge is this, but if so, can I determine this with a multimeter and know with some certainty that the fault is with the laser?
Thanks
  • · Replies 22 ·
  • · Replies 25 ·
