How to determine the intervals of decrease or increase
The discussion centers on analyzing the function f(x) = (x^2 - x - 1) / (x - 1) to determine its domain, intercepts, asymptotes, intervals of increase or decrease, and concavity. The domain is all real numbers except x = 1. The vertical asymptote is at x = 1, and there is no horizontal asymptote. The first derivative indicates no local maxima or minima due to imaginary roots, and the second derivative shows no points of inflection, complicating the determination of concavity.
  • Understanding of rational functions and their properties
  • Knowledge of derivatives and critical points
  • Familiarity with asymptotic behavior in calculus
  • Ability to perform polynomial long division
  • Study the concept of vertical and horizontal asymptotes in rational functions
  • Learn how to apply the first and second derivative tests for local extrema
  • Explore polynomial long division techniques for rational functions
  • Investigate the implications of imaginary roots on function behavior
Students and educators in calculus, particularly those focusing on curve sketching, rational functions, and derivative analysis.
F.B
Im having a problem with curve sketching i can't figure out how to do this problem. I am confused.
Heres the question
1. For the following curve find:
a)the domain
b)the intercepts
c)the asymptotes
d)intervals of increase or decrease: local maximum and minimum
e)concavity and the point of inflection
x^2 - x - 1 / x-1
Heres my work.
a) the domain is x = 1
b)Let y=0
y = 0 - 0 - 1/ 0-1
y=1
Let x = 0
x^2 - x - 1 = 0
x = 1.62 or x = 0.62
c) Vertical asymptote:
x = 1
Horizontal asymptote
x^2 - x - 1 / x-1
y = x - 1/ x-1
Therefore it has an slant asympote at y = x
Heres where it gets fun
d) y = x^2 - x - 1/x-1
y'= x^2 - 2x + 2/ (x-1)^2
let y'= 0
x^2 - 2x - 2 = 0
x = 1 +/- i
Do i say that it doesn't have an maximum or minimum point because they are
imaginary?
e) y'' = -2/(x-1)^3
Let y''=0
-2 cannot equal 0
So there are no points of inflection, but then how do i determine the
concavity when my first derivative is based on imaginary numbers.
I have never encountered one like this. I don't know how to determine the intervals of decrease or increase because of i, so can you please help me.
Heres the question
a)the domain
b)the intercepts
c)the asymptotes
x^2 - x - 1 / x-1
Heres my work.
How do you get that? The domain is the set of all x where
f(x) = x^2 - x - 1 / x-1
So x = 1 is NOT part of the domain of f(x).
b)Let y=0
You must mean let x = 0 since you are trying to find the y intercept. The y intercept is a point (0,y)
Let x = 0
Again, this should be y = 0 to find the x intercept.
x^2 - x - 1 = 0
These are the correct solutions to the quadratic equation.
x = 1
Correct
x^2 - x - 1 / x-1
y = x - 1/ x-1
You will have to explain why you did this. I don't follow this.
let y'= 0
x^2 - 2x - 2 = 0
x = 1 +/- i
You lost me there.
AM
Heres the question
a)the domain
b)the intercepts
c)the asymptotes
x^2 - x - 1 / x-1
Heres my work.
Assuming that y= x^2- x- 1/(x-1), this is exactly backwards: the domain is all x except x= 1.
b)Let y=0
y = 0 - 0 - 1/ 0-1
y=1
As Andrew Mason pointed out, actually, you've let x= 0 to find the y-intercept.
Let x = 0
x^2 - x - 1 = 0
No, you let y= 0 so you get the equation x^2- x- 1/(x-1)= 0 which is the same as x^2- x= 1/(x-1) or (x-1)(x^2-x)= (x-1)^2(x)= 0. The x intercepts are x= 0 and x= 1.
x = 1
Ok.
x^2 - x - 1 / x-1
y = x - 1/ x-1
But the problem didn't say "slant asymptote"- it asked about a horizontal asymptote- and there is none. No, y= x is not a "slant asymptote" anyway. How did you go from y= x^2- x- 1/(x-1) to y= x- 1/(x-1)??
x^2- x is NOT equal to x!
?? Are you saying that the derivative of x^2 is x^2 and the derivative of -x is -2x? Surely you know better than that! Oh, and the derivative of -1/(x-1)= -(x-1)^(-1) is NOT 2/(x-1)^2, although I admit that's harder. For all of those you can use the fact that the derivative of
x^n is nx^(n-1).
let y'= 0
x^2 - 2x - 2 = 0
x = 1 +/- i
imaginary?
Go back and do the derivative correctly!
y'' = -2/(x-1)^3
Let y''=0
-2 cannot equal 0
Again, go back and do the first derivative correctly. You can't get the second derivative until you do that.
For future reference, if you had a problem where the derivative was never 0, such as f(x)= x, then the derivative always has the same sign and so there is just one "interval of decrease or increase".
To find the y-intercept you have to solve for y correct? Thats why you let x=0 to find the find what y is when equals 0. To find the x-intercept you have to let y be 0 and then you solve for x to determine what x is when y is 0. And Halls of Ivy maybe i should have made the question a bit clearer. The function is this:
y=(x^2-x-1)/(x-1), does this help?
For the horizontal asymptote we have to find one even it is a slant one.
By doing long division i get the following:
y = (x) - (1)/(x-1).
My derivatives are all right because when i use the question rule i get that same thing.
But i figured how to find the intervals of increase and decrease. Because the vertical asymptote x=1, i can use those as my intervals. So x<1 and x>1.
But i still have one problem. If i use those as my intervals, when i do that chart with the test values, do i sub a number <1 and >1 into the original function or the first derivative.
My other problem is determining the concavity. Because i don't have a point of inflection, how would i determine where the function is concave up and down.
That is correct.
Halls of Ivy's point still remains valid, the function is defined everywhere except at x = 1. Therefore, the domain of the function is x \in\Re \; , \; x \neq 1
I'm afraid you derivative is incorrect. Try and do it again, perhaps it would be easier to write it as;
f(x) = (x^{2} - x -1)(x-1)^{-1}
The concavity is given by the sign of the second derivative. Watch out though: the fact that there are no zeroes doesn't mean the concavity is the same everywhere, remember your vertical asymptote!
