How to Evaluate This Integral Using a Table of Integrals?
  • Level: Undergrad
  • Thread starter EngWiPy
    Integral
14 replies · 3K views · last reply
EngWiPy
Hello all,
I need to evaluate this integral
[tex]\int_0^{\infty}(1+\alpha_2)^{-2}\left(\alpha_2+b\right)^{-1}\,d\alpha_2[/tex]
I found the following integral in the table of integrals (eq 3.197.1, 7th edition)
[tex]\int_0^{\infty}x^{v-1}(\beta+x)^{-\mu}(x+\gamma)^{-\rho}\,dx=\beta^{-\mu}\gamma^{\mu-\rho}B(v,\mu-v+\rho)_2F_1(\mu,\,v;\,\mu+\rho;1-\frac{\gamma}{\beta})[/tex]
The integral and the conditions are in the image attached. Comparing the two integrals I set ##v=1,\,\beta=1,\,\gamma=b##, which implies that ##\mu=2## and ##\rho=1##. I satisfy the last two conditions, but I'm not sure about the first two. What does it mean arg x if x is a constant?
##b## varies in a loop, and when I evaluate the integral I get results. However, the final result, in which the above integral is a part, isn't right. I'm not sure where the error is, and I wanted to make sure it isn't in using the integral.
I appreciate any help. Thanks
S_David said:
Hello all,
It doesn't say arg(x) in the integral you found -- it says arg(β) and arg(γ). This implies that these parameters are complex. In the integral x is real.
The integral you found should work, but I don't know what the B and F1 functions are. The integral could be evaluated using much simpler means, though, by using partial fractions decomposition to split the integrand into three parts.
The decomposition would look like this:
$$\frac{1}{(a + 1)^2} \frac{1}{a + b} = \frac{A}{a + 1} + \frac{B}{(a + 1)^2} + \frac{C}{a + b} $$
After you determine the constants A, B, and C, integrate each term and then evaluate your three improper integrals.
The equation is valid for some complex numbers as well, the condition on the complex argument are satisfied for positive real values (and also for all complex values with a positive imaginary component).
It is not necessary to use such a powerful formula, for integer exponents you can use partial fraction decomposition.
Mark44 said:
...The integral could be evaluated using much simpler means, though, by using partial fractions decomposition to split the integrand into three parts.
Thanks, but why ##\frac{A}{a + 1} + \frac{B}{(a + 1)^2} + \frac{C}{a + b} ## and not ##\frac{A}{(a + 1)^2} + \frac{B}{a + b} ##? I did the latter, and I got the following:
[tex]\frac{1}{(x+1)^2(x+b)}=\frac{1}{b-1}\left[\frac{1}{(x+1)^2}-\frac{1}{x+b}\right][/tex]
Then I used the integral formula (attached):
[tex]\int_0^{\infty}\frac{x^{\mu-1}}{(1+\beta\,x)^v}\,dx=\beta^{-\mu} B(\mu,\,v-\mu)[/tex],
where ##B(.,.)## is the beta function. I got the following:
[tex]\int_0^{\infty}\frac{1}{(x+1)^2}\,dx=B(1,1)[/tex]
and
[tex]\int_0^{\infty}\frac{1}{(x+b)}\,dx=B(1,0)[/tex]
But evaluating ##B(1,1)-B(1,0)## in Mathematica gives me ComplexInfinity! Why?
  • Beta function integral formula: integral from 0 to infinity of x^(mu-1) over (1+beta x)^nu dx equals beta^(-mu) times B(mu, nu-mu), valid for |arg beta| < pi, Re nu > Re mu > 0. Cited as FI II 775a, ET I 310(19).
Because that's how you do it when you have repeated linear factors (i.e., (a + 1)2). If you break it up into only two terms, you don't get the correct decomposition. You need to break the original integrand into three terms, not two.
and
Actually, I did it as you said, and got A=0, which led to the same result as I did it!
Then you made a mistake -- A is not 0. I'm pretty confident in this, as I checked my work.
If you show what you did, we can figure out where you went wrong.
OK. So first we have
[tex] \frac{1}{(x + 1)^2} \frac{1}{x + b} = \frac{A}{x + 1} + \frac{B}{(x + 1)^2} + \frac{C}{x + b}=\frac{A(x+1)(x+b)+B(x+b)+C(x+1)^2}{(x+1)^2(x+b)}[/tex]
This implies that
$$A(x+1)(x+b)+B(x+b)+C(x+1)^2=1$$
For ##x=-1## we get ##B=\frac{1}{b-1}##
For ##x=-b## we get ##C=-\frac{1}{b-1}##
For ##x=0## we get ##Ab+Bb+C=Ab+\frac{b}{b-1}-\frac{1}{b-1}=Ab+1=1## which implies that ##A=0##.
Where did I err?
This implies that
Where did I err?
In your calculation for C. I get C = ##-\frac{1}{(b - 1)^2}##
I think in this case ##C=\frac{1}{(b-1)^2}##, isn't it? But you are right, I missed the square, and don't know how I missed it THREE times! Anyway, thanks
Correct. I misread my work.
One little mistake will throw everything off. That's why I checked my work. After substituting the values for A, B, and C, I ended up with ##\frac{(b - 1)^2}{(b - 1)^2} \equiv 1## (except if b = 1).
The integral I attached in post #4 works only for ##(x+1)^2##. How to evaluate the other integrals? I found this indefinite integral
$$\int\frac{1}{ax+b}\,dx=\frac{1}{a}\ln|ax+b|$$
Can I use this?
Can I use this?
Yes. For both integrals a = 1.
Right, but the integrals in my case are definite. Do I need to evaluate the result as ##\left.
\frac{1}{a}\ln|ax+b|\right|_0^{\infty}
##. This will result in ##+\infty##!
All three are improper integrals, so you can't simply substitute ##\infty## into the antiderivatives. You'll need to use limits. Any calculus textbook should have a section on dealing with improper integrals.
