How to find angle whit system of equations
The discussion revolves around determining the angle at which to kick a ball to barely clear a wall, given an initial velocity and specific distances. The problem involves concepts from projectile motion, including vertical and horizontal displacement equations.
  • Participants discuss using a system of equations to relate time, horizontal distance, and vertical height. There are attempts to isolate variables and substitute values into the equations. Questions arise regarding the interpretation of variables and the difficulty in manipulating trigonometric functions.
Some participants have provided clarifications on variable definitions and suggested methods for rearranging equations. There is acknowledgment of the complexity involved in combining trigonometric terms, and a participant has expressed understanding after receiving an explanation.
Participants note the ambiguity in the height chosen for the ball's trajectory and discuss the implications of different height values on the calculations. There is also a mention of the assumption that the initial vertical displacement is zero.
felipenavarro
i kick a ball with an initial velocity of 18m/s. there is a wall at 8m that has a height of 1.5 meters. whith what angle should i kick the ball so that it bearly passes the wall?
first equation: hf= 1/2gt^2+vit+hi
second equation: V=Δx/t
so what i am trying to do is a system of equations isolating t in the second equation and placing it in the first equation. in velosity in the y direction i use 18sin(θ) and for v in the x i use 18cos(θ).
Also as final heigth i am using 1.6m(just a little higher than the wall) and as xfinal i am using 8.1m(also bearly passing the wall)
the problem is i can't soleve the equation. is this the right way to do it?
So you have [tex]s_y = v_{oy}t -\frac{1}{2}gt^2,[/tex] and you have values for [itex]s_y[/itex] and [itex]v_{oy}.[/itex]
If you know the wall is 8m away, and you know [itex]v_{ox},[/itex] then by rearranging [itex]s_x = v_{ox}t[/itex] for [itex]t[/itex] and subbing into the above eqn, you should be able to solve for [itex]θ.[/itex]
It is just a case of rearranging the final eqn for [itex]θ.[/itex] Is this the part you are having difficulty with?
sorry what is sy(changes in y?) , and yes that is where i am having trouble. i end up with cosines and sines and can't unite them or cancel them or anithyng
It is the right way in principle but "just a little higher" can mean anything. Why not 1.55 m? or 1.51 m? So choose y=1.5 m at x=8 m.
After eliminating t, you get an equation which contains both the tangent and the cosine of theta. (y=tan(θ)x-(g/2)x2/(182cos2(θ)). You certainly know that cos2(θ)=1/(1+tan2(θ)). Use that relation and you get a quadratic equation for tan(θ).
ehild
sorry what is sy(changes in y?) , and yes that is where i am having trouble. i end up with cosines and sines and can't unite them or anithyng
[itex]s_y[/itex] is the vertical displacement of the object. I implicitly assumed [itex]s_o = 0[/itex] in the equation [tex]s_y - s_o = v_{oy}t -\frac{1}{2}gt^2[/tex]
now i got it, great explenation! thanks
  • · Replies 45 ·
