How To Find Initial Angular Velocity
4 replies · 4K views · last reply
rockerdude1210
The angle of a pendulum is θ(t)=(0.270rad)cos(4.00t+1.00π), where t is in seconds.
Determine the initial angular velocity.
ω=2πf
[/B]
I solved for the frequency, which was 6.37E-1 Hz and subbed it into the formula above and got 4rad/s which is the same ω in the equation but it is wrong. Am I missing something because I can't figure out what is wrong with my method.
The formula ω=2πf is not applicable to this case. That formula is for uniform circular motion, which has constant angular velocity, not for a pendulum, which has variable angular velocity.
From the formula for θ you can deduce that initially (at time t=0) the pendulum is at its highest point, and hence at zero angular velocity.
Ah okay, thanks!
Did you just sub in 0 for t which gave you -0.270 at the θ to figure out that it was at its highest point?
