How to find the area of an n-dimensional triangle?
  • Thread starter Thread starter LFCFAN
    Area Triangle
To find the area of an n-dimensional triangle using vectors, it's essential to recognize that the triangle remains a 2-dimensional object within n-dimensional space. The area can be calculated using the dot product and norms of the vectors representing the triangle's sides. A proposed formula involves finding the angle between the vectors and using it to derive the area as A = (1/2) * ||A|| * ||B|| * sin(angle). Simplifying the sine of the angle can be achieved through trigonometric identities, leading to a more straightforward expression. Understanding these concepts allows for generalization to higher dimensions effectively.
LFCFAN
How to find area of an n-dimensional triangle using vectors?
bump
First, what do you mean by the area of such an object? Do you mean its n-dimensional volume?
Second, please show some attempt or thoughts on the matter. Anything relevant you've been taught? Can you do it for 3 dimensions?
Find the area of the triangle with sides
A = (a1 ... an)
B = (b1 ... bn)
and A-B = (a1-b1 ... an-bn)
I don't even know where to start. I know how to do it in 3D with the cross product, but that obviously won't work for higher dimensions.
So I need help generalizing for Rn.
? Let me know if I've explained the problem sufficiently
There are n-dimensional generalisations of the cross-product, one of them will work.
Alternatively, use the dot product and some vector additions in the same way you can do it in two dimensions.
Some elaboration on that would help, is possible?
Did you draw a sketch? What you try so far to follow that idea?
A = (a1 ... an)
B = (b1 ... bn)
Your terminology is incorrect and highly misleading. You are not talking about an "n-dimensional triangle"; you are talking about a standard triangle located in an n-dimensional space. Your triangle is still a "2-dimensional" object. Recognizing that is very important for solving the problem.
I've literally typed out the question as it has been given.
I think take it as a standard triangle in n-dim space
OK, so we are agreed on that. Now what would you do next?
If I were doing this problem I would look for formulas for a triangle that involve only norms and inner products of the vectors forming the triangle's sides.
A = {2,1,2,4}
B = {4,1,6,2}
angle = arccos( (A.B)/(norm(A)*norm(B)) )
area = (1/2)A.B sin(angle)
Is this correct? if yes, it is easy to generalize for Rn.
LFCFAN said:
A = {2,1,2,4}
B = {4,1,6,2}
You can make it a lot neater by expressing ##\sin(\arccos(u))## in a simpler way---just think about what ##\arccos(u)## actually means, and what that says about its sine.
One method: draw a triangle with angle \theta= arcos(u). Then, since cosine is "near side over hypotenuse", we can label the hypotenuse 1 and the near side u. By the Pythagorean theorem, the opposite side has length \sqrt{1- u^2} so that sin(arcos(u))= sin(\theta)= \sqrt{1- u^2}/1= \sqrt{1- u^2}.
Or: since sin^(\theta)+ cos^2(\theta)= 1, sin(\theta)= \sqrt{1- cos^2(\theta)}. So sin(arcos(u))= \sqrt{1- cos^2(\theta)}= \sqrt{1- cos^2(arcos(\theta))}=\sqrt{1- u^2}
  • · Replies 30 ·
