How to Find the Center and Radius of a Circle: Circle Equation Help
  • Thread starter Thread starter MrNeWBiE
    Circle
The discussion revolves around determining whether given equations represent circles and finding their centers and radii. The specific equations under consideration are quadratic in nature, involving both x and y variables.
  • Participants discuss the standard form of a circle's equation and the process of completing the square to identify the center and radius. Questions arise regarding how to confirm if an equation is indeed a circle and how to interpret negative values for radius.
There is an ongoing exploration of the conditions under which an equation represents a circle. Some participants provide insights into the implications of negative radii, while others seek clarification on the definitions and properties of circles.
Participants are navigating the complexities of quadratic equations and the specific conditions that define a circle, including the implications of completing the square and the interpretation of negative values in the context of radius.
MrNeWBiE
hi
determine if whether it's circle or not , if yes find the center and radius
1) 2x^2 + 2y^2 - 5x + 4y - 1 =0
2) x^2 + y^2 + 4x + 8y + 25 =0
1) center (5/4,-1)
2) center (2,4)
well i need help in how to find the " radius " and how to know if it's circle equation or not ,,,
If it is a circle, it can be put into the form
(x-a)2+(y-b)2=r2
with center (a,b) and radius 'r'.
i know that ,,,, but now it's expanded ,,,
so i will got b^2 + a^2 - r^2 in one side ,,,,,
how i will know if it's circle and the " r " ?
Gather all the terms with 'x' and compete the square, do the same for the 'y', then move all the constants to the right side of the equation and that will be your r2
i completed the square and i got the points ,,, but how to know if it's circle equation ? because #2 is not ,,,
but i don't know why ,,,,
The general equation of circle are in the form of x^2+y^2+2gx+2fy+c=0 and since the equations that you mentioned are in this form I am pretty sure they're a circle.
is not circle equation am sure because I see it in my book ,,,,
and I don't know why it's not ,,,
No it's not a circle ,, Put "x^2 + y^2 + 4x + 8y + 25 =0 " in circle equation :
(x+2)^2+(y+4)^2=-20 ,, the radius is minus so it's not a circle :smile:
aha ,,,, thanks Lord
no problem :biggrin:
Would you please elaborate why?
Why what ? it's not a circle ?? ,, if yes here's why :
the equation
>> (x^2+4x+...)+(y^2+8y+...) = -25 [complete the square for both of them]
>> (x+2)^2+(y+4)^2 = -25+4+16 [add on both sides 4 & 16 to be able to complete the square]
>>(x+2)^2+(y+4)^2= -5 [ you get the radius -5 which tells you that there is no circle with minus radius]
hope you understand now ,, and sorry for the wrong answer before (r=-20)
I don't understand why a circle can't have negative radius. For example, consider this circle with equation x^2+y^2=0, which has its center at origin and passes through points P(x, 0) & Q(-x, 0). If the radius of a circle is defined as the distance from the center to any point on the circle, then the circle in the above example would have negative radius in the 2nd and 3rd quadrant. Thanks for the reply in advance =)
Distances aren't negative.
(x-a)^2 + (y-b)^2 \ge 0. You can't have it equal to a negative number and find any (x,y) that work.
The equation x^2 + y^2 = 0 represents a degenerate circle, a circle whose radius is 0. This "circle" DOES NOT pass through points P(x, 0) and Q(0, y), unless x = 0 and y = 0.
@rock.freak667: I know but I got a little confused by the structure of the equation.
@LCKurtz: Thanks that helps me understand the concept better :)
@Mark44: I actually though about that after posting :D
Thanks for the help guys =)
  • · Replies 16 ·
10K
