How to Find the Current in a 6 Ohm Resistor?
The discussion revolves around finding the current in a 6 ohm resistor within a circuit, with an emphasis on calculating power dissipation. Participants are exploring concepts related to electrical circuits, specifically resistance and current flow.
  • Participants discuss combining resistors and calculating equivalent resistance. Questions are raised about the voltage across the equivalent resistance and the current through various branches of the circuit.
Some participants have provided guidance by suggesting a sequence of questions to answer in order to progress towards finding the current. There is acknowledgment of correct calculations regarding equivalent resistance and voltage, but further exploration is encouraged.
Participants are working with specific values for resistance and voltage, and there is mention of applying Kirchhoff's Voltage Law to analyze the circuit further. The original poster's initial assumptions and calculations are being examined and discussed.
RedDead
hello
Find the power dissipated in the (6 ohm) resistor.
the circuit is in the attachments
i know that P in the resistor = (i^2)*R
but how can i find the current in that 6 ohm resistor?
thanks
Think about first combining resistors. Reply back to show your work for that. From there, it should be simple to get the I in the 6ohm resistor.
Answer these questions in order and you'll get there.
1.) What is the equivalent resistance of this circuit?
2.) What is the voltage across that equivalent resistance?
3.) What is the current through the right branch of the circuit? (Mr. Ohm will help you here)
Now you're ready to compute the power dissipated in that resistor.
i got R equivalent = 3.2 ohm
the voltage across R equivalent = 32 volts
I in the right branch = 8 A
am i right?
Ack! You know what, I made the problem a little too simple in my head. You're right about the equivalent resistance and the voltage across it. That means that the voltage across the 16 Ohm resistor is 32V, so there's 2A going through it. So the other 8A goes into the other resistors. You can apply Kirchhoff's Voltage Law at this point to get the voltage across the 6 Ohm resistor.
thats exactly what i did ;)
thanks you!
  • · Replies 18 ·
