How to find the equation of a parabola with only 3 pts.
  • Thread starter Thread starter redretro
    Parabola
To find the equation of a parabola given three points and knowing the axis of symmetry is parallel to the y-axis, one can use the general form y = ax^2 + bx + c. By substituting the three points into this equation, a system of equations is created. The discussion reveals attempts to solve for the coefficients a, b, and c, with calculations leading to a = 1/30 and b = 215/6. However, there are noted discrepancies in the calculations, particularly in determining the value of b. The conversation emphasizes the importance of careful algebraic manipulation to avoid errors in solving the system.
redretro
If you have 3 points of a parabola that are'nt the vertex and the only other information you receive is that the A.O.S is parallel to the y-axis how would you acurately find the equation? Everytime I try, I always end up with odd fractions... the pts are (-3,-4),
(-1,-1), (2,3)
2. Homework Equations : general form: y=ax^2+ bx+c standard form: y-h=a(x-k)^2 a=1/4l l is the distance from the vertex to either the directrix or the focus, also that the equations opens either up or down...
Attempt:(-3,-4) -4=9a-3b+c (-1,-1) -1=a-b+c (2,3) 3=4a+2b+c
(-1)(-4=9a-3b-c) (-1)(-4=9a-3b-c)
(-1= a -b+c) (3=4a+2b+c)
+ ___________ +____________
3=-8a+2b 7=-5a+5b
(-5)(3=-8a+2b)
( 2)(7=-5a+5b)
+_____________
1=30a a=1/30
7=-5(1/30)+5b 7= -5/30+5b 215/30=5b 1075/30=b b= 215/6 a=1/30 b=215/6
3=4a+2b+c 3=4/30+2(215/6)+c 86/30= 215/3+c c=-2064/30
after that point: I thought something went wrong and attempted to redo it...-.-
I get a = 1/30 also, using determinants to solve the equations for it. I think you're on the right track...
But in your solution for b, I think there's an issue...
7=-5(1/30)+5b
7= -5/30+5b
215/30=5b
1075/30=b <--- (see the issue?)
b= 215/6
okay thanks ^.^ I think I understand it more.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
