How to find the integral of x(3x^2 + 5)^1/4
  • Thread starter Thread starter brutalmadness
    Integral
The integral of the function x(3x^2 + 5)^(1/4) can be solved using substitution and the power rule for integrals. The substitution u = 3x^2 + 5 leads to du = 6x dx, simplifying the integral to (1/6)∫u^(1/4) du. After applying the power rule, the correct evaluation yields (2/15)(3x^2 + 5)^(5/4) + C as the final answer. Attention to detail is crucial, as an extra integral sign can lead to confusion in the solution process.
  • Understanding of integral calculus
  • Familiarity with substitution methods in integration
  • Knowledge of the power rule for integrals
  • Basic algebraic manipulation skills
  • Practice integration techniques using substitution with various functions
  • Review the power rule for integrals and its applications
  • Explore common pitfalls in integral calculus to avoid mistakes
  • Study advanced integration methods such as integration by parts
Students studying calculus, particularly those working on integration techniques, and educators looking for examples of common mistakes in solving integrals.
brutalmadness
\intx(3x^2+5)^1/4
2. The attempt at a solution
u=3x^2+5 du=6x
1/6\int6x(3x^2+5)^1/4
this is where I'm getting sloppy, i think...
1/6\intdu(u)^1/4
1/6\int4/5(u)^5/4
\int2/15(3x^2+5)^5/4
and then i get stuck.
brutalmadness said:
\intx(3x^2+5)^1/4
u=3x^2+5 du=6x
1/6\intdu(u)^1/4
Good so far...(except du=6xdx and you forgot to include a few dummy variables throughout the problem, but you are accounting for them in your attempt--just remember to write them down too)
brutalmadness said:
1/6\int4/5(u)^5/4
Where are you getting the integral sign from in this part of the problem?
i was trying to use the power rule for integrals (x^n+1/n+1). but i have a feeling i can't do that. haha :)
then i pulled the 1/6 back into it and multiplied it out (1/6 times 4/5=2/15).
No, you were doing it right, no need to second guess yourself. The power rule for integrals is all you need to solve this.
Try to integrate the following again:
1/6\intu^(1/4)du
Rather, another way for me to put it:
is \intudu = \int0.5u^2du ?
no, they wouldn't be equal. for example, does 5=0.5(5)^2? no; 5 does not equal 12.5
did i pull my denominator up incorrectly? if (x^n+1/n+1) is (x^.25+1/.25+1), then (x^1.25/1.25). so to pull up the denominator...
Ok, if those two aren't equal, then why would
1/6\intdu(u)^1/4 = 1/6\int4/5(u)^5/4
Your denominator and everything is fine, you just have an extra integral sign floating around after you already correctly evaluated the integral. I didn't outright say it since I thought you'd notice it, but I suppose my references were a bit too vague.
Once you get rid of the extra integral sign at the point where you are "stuck", you would have 2/15(3x^2+5)^5/4 (+C), and that would simply be your final answer, unless there was an initial condition or something.
oh wow, that's what i get for trying to do calculus late at night. i was trying to evaluate an integral after i already evaluated it. so my final answer was correct... just need to watch out and make sure i drop the integral sign.
should have been...
(1/6)(4/5)u^5/4
2/15(3x^2+5)^5/4+C
thank you so much.
  • · Replies 18 ·
  • · Replies 44 ·
  • · Replies 20 ·
  • · Replies 25 ·
