How to find the tension using the F=ma formula
To find the tension in the string connecting a 4.0 kg and a 6.0 kg mass over a pulley, apply the F=ma formula by analyzing the forces acting on each mass. Each mass experiences gravitational force downward and tension upward, which can be expressed as T = m*g for each mass. The difference in weight between the two masses will help determine the net force and thus the tension in the string. Understanding tension in physics refers to the force transmitted through the string, acting in opposite directions on the masses. This explanation clarifies the concept and calculation of tension in this scenario.
blue__boy
A 4.0 kg and 6.0 kg masses are connected by a string over a pulley. What is the tension in the String?
I have no idea how to find the tension using the F=ma formula
Can someone please help me?
Please also explain tension in terms of the word meaning in Physics.
Thank you very much!
Your reply really helps me!
Thank you very much! =)
  • · Replies 38 ·
  • · Replies 47 ·
  • · Replies 21 ·
