How to find two constants in an equation
  • Thread starter Thread starter Aerosion
    Constants
To find the constants c1 and c2 in the equation x = c1 cos(t) + c2 sin(t) for the initial value problem x'' + x = 0, initial conditions x(π/6) = 1/2 and x'(π/6) = 0 are used. The first equation derived from the initial condition gives sqrt(3)c1/2 + c2/2 = 1/2. To find a second equation, the first derivative of x is calculated and the second condition x'(π/6) = 0 is applied. This results in a system of two linear equations with two unknowns, allowing for the solution of c1 and c2. Solving these equations will yield the required constants for the problem.
Aerosion
i'm trying to find two constants in the same equation. its an initial value problem
there's a two parameter family x=c1cost+c2sint with initial conditions x''+x=0, x(pi/6)=1/2, and x'(pi/6)=0
so I'm trying to find c1, and i equate the problem to 1/2 and subsitute the t's for pi/6, so it looks like
1/2=c1cos(pi/6)+c2sin(pi/6)
which of course equals sqrt(3)c1/2 + c2/2
but how do i get the values of c1 and c2? I've tried everything and i need them to find a solution
well, you already found one relation sqrt(3)c1/2 + c2/2=1/2, to find another relation,
take the first derivative of x=c1cost+c2sint, and apply the second contidion that you are given x'(pi/6)=0
so you'll get two lin. eq in two unknowns, c1,c2, and u should be able to solve it.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 27 ·
  • · Replies 19 ·
