How to get position operator in momentum space?
5 replies · 3K views
azoroth134
Hi, I wish to get position operator in momentum space using Fourier transformation, if I simply start from here,
$$ <x>=\int_{-\infty}^{\infty} dx \Psi^* x \Psi $$
I could do the same with the momentum operator, because I had a derivative acting on |psi there, but in this case, How may I get the ih d/dp thing for the position operator, please give some hint
Well, since you only wanted a hint...
Express ##\Psi(x)## in terms of its Fourier transform ##\tilde\Psi(p)## .
I already did that, I just don't know what to do after that, I don't have any derivative to perform on x or p
For a function ##f(x)## and its Fourier transform ##F(k)## (assuming it has one), we have the relation ##f'(x) = FT[ikF(k)]## and the inverse transform ##ikF(k) = FT^{-1}[f'(x)]##. Using this how would you write ##x\psi(x)## in momentum space?
azoroth134 said:
I already did that [...]
Heh, then you should show your work. (Asking only vague questions makes it harder for others to help you constructively.)
