How to get roots of this complex equation
In summary, the conversation is about finding 4 complex roots for the equation λ^4=0 in the context of solving a differential equation with constant coefficients. The discussion touches on the idea of repeated roots and the method of variation of parameters to find the complete solution. However, the main question remains unanswered and the individual is seeking further help to find 4 different complex roots for the given equation.
pm1366
hello, i am stucked at an article from sciencedirect . somewhere it gives me the following equation and then it tells that this equation must have 4 complex roots!
the variable is lambda and we want to find 4 lambda complex roots
λ^4=0
i am amazed how we can get 4 complex roots from this equation as it seems to have roots equal to zero !
Any help would be greatly appreciated!
The four roots are:
0∠0°
0∠90°
0∠180°
0∠270°
The Electrician said:
The four roots are:
0∠0°
0∠90°
0∠180°
0∠270°
thanks for reply but i forgot to explain more, here it is:
we have 3 linear partial differential equations:
http://i45.fastpic.ru/big/2012/1027/8f/429c9d2a3bd454656212ed589156f38f.jpg
now for homogeneous solution we're going to substitute below Equation into Eqs. (11) and (12) at the above picture:
http://i44.fastpic.ru/big/2012/1027/e0/ef375cf97523a4d907b0d504bd9664e0.jpg
the rest is explained below:
now what I've done is substituting Equation 17 into Eqs. (11) and (12), the result is these 2 equations ("s" same as "x" ):
http://i45.fastpic.ru/big/2012/1027/86/b87473ecf6018ce0ab166cfb71a4c086.jpg
don't mind what the coefficients A,D & B are... they're constants.
also L differential operators are given in Appendix and I've used them
now the determinant of the coefficient matrix must vanish (=0) , the result would be this way:
http://i44.fastpic.ru/big/2012/1027/1a/e6d25171f9daaf47e13b1197ff7bf81a.jpg
and in this equation we must find 4 complex roots , i mean 4 complex lambda's
( maybe we can think this equation is correct for all values of x , so we may only have λ^4=0 )i think your answers are not applicable here
Big thanks to anyOne help me in this matter...
Yes, obviously the only root is [itex]\lambda= 0[/itex]. Since you now tell us that this is the characteristic equation of a differential equation with constant coefficients, that means that four independent solutions to the equation are e0x= 1, x, x2, and x3.
thanks...this is some likely answer , but here in this article we need 4 different lambda's .
besides, as u see the four independent solutions are different from those u mentioned...that is exponential in the series form and 4 lambda's are included:
http://i45.fastpic.ru/big/2012/1027/2f/678839cd8c87271c8453274f1a30b72f.jpg
That statement is assuming the roots are different. See if you can find something in the article talking about repeated roots and what happens for those.
no :frown: ,no where talking about that ... it is an article about cylindrical shells , i can give it to anyone who want to have a look...
Look up 'repeated roots' and 'differential equations' in your textbooks or on the internet.
The solution strategy is this:
You have a homogeneous differential equation (ie one that solves Dy = 0, where D is some differential operator).
Taking a function and adding derivatives of itself to get zero is only possible with the exponential function, so it is assumed that the solution will be of the form y=eλt . Plug that into the differential equation and you have conditions on λ for that solution to work. The condition on λ is called the characteristic equation . Since y=eλt for a specific λ satisfying the characteristic equation has been found to solve the homogeneous equation, a sum of all eλt with every λ found must also solve the homogeneous equation because differentiation is linear. So the total homogeneous solution is Ʃ Aieλit as your excerpt states.
From other considerations we know an nth order differential equation has n independent functions that satisfy the homogeneous equation. If some of the λ are repeated (eg you have four zeroes for λ), you are not finding all those functions so you have to have another way to find them. That part the article hasn't mentioned but HallsOfIvy gave you the solutions -- the idea is to assume the solution is the form of eλt, teλt, t2eλt, ... the highest power of t depending on how many repeated roots you have (if you have four repeated roots, you need four equations with that root). You can confirm these also satisfy the differential equation by substitution and the resulting complete solution will be a summation of all such functions you found.
The idea of doing this is called 'variation of parameters'. The notion was Aeλt is one solution, what if A was allowed to be a function of time, would that work? Plug into the differential equation, and lo and behold, it does with A=tn for some n.
@aralbrec
thank you for your help, i get what you're saying , but please look at this red line I've drawn in this picture:
it is showing that there must be 4 different lambda for the solution and not repeated lambda's ( λ i=1,2,3,4 )
in this picture there's no solution for repeated roots...
i mean we must have 4 different roots , but the problem is how to find four different complex roots!
suppose that we know lambda is complex from the beginning ,now how to find 4 complex roots from λ^4=0 or similarly Z^4=0 assuming Z::complex ? is there any kind of solution except zero?
any other ideas friends ?
Related to How to get roots of this complex equation
1. How do I find the roots of a complex equation?
To find the roots of a complex equation, you can use the quadratic formula or a calculator with complex number capabilities. You can also use the method of substitution to solve for the roots.
2. What is the difference between real and complex roots?
Real roots are solutions to an equation that are only made up of real numbers, whereas complex roots involve imaginary numbers. Complex roots come in pairs, with one being the conjugate of the other.
3. Can complex equations have multiple roots?
Yes, complex equations can have multiple roots. In fact, most complex equations have multiple solutions. This is because complex numbers can have both a real and imaginary component, allowing for more possible solutions.
4. How do I know if my solution for a complex equation is correct?
To verify if your solution for a complex equation is correct, you can plug the values back into the original equation and see if it satisfies the equation. You can also use a graphing calculator to graph the equation and see if your solution falls on the curve.
5. Is there a general method for finding the roots of any complex equation?
There is no one specific method for finding the roots of any complex equation. However, there are various techniques that can be used depending on the complexity of the equation. It is important to have a good understanding of algebra and complex numbers to effectively solve complex equations.
  • Differential Equations
